Hey people, can anyone tell me what the actual diferance is with the Spac vt suspension compared to the STD, apart from being a bit lower? As I can't physicaly see any changes with the springs, shocks or sway bars but a huge diferance in handling? I'm trying to take the susp off my Spac onto my Aclaim and want to know what parts to change?![]()
All the difference is, is that its a bit lower and much stiffer, but should fit straight in... someone might know more about it...![]()
Thanks, I have recently got a workshop manual and it states that the front stabiliser bar is 27mm (1mm thicker), front springs are shorter and thinner, no specs on the rear tho. Just if anyone wants to know. It doesn't really explain how the back tyre lifts off the ground first when I jack up the front corner tho![]()
