Results 1 to 15 of 15
Thread: VS center bore size in millimeters
    VT Acclaim Wagon
    Oct 2008
    Default VS center bore size in millimeters
    I have just spent an hour searching this and can't find it on these forums or the web...what is the diameter of the VS road wheel center bore?
    VB SL/E
    Dec 2008
    AFIK Commodore Centre hubs are 69.5mm pre VE and 66.9mm VE.
    Doesn't answer your question but hope it helps.
    VT Acclaim Wagon
    Oct 2008
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    DBA rotor catalogue shows the VS centre hole as being 70mm and VT-VY as being 71.5mm. Not sure if this is the same as the wheel centre bore size.
    Feb 2011
    NEWCASTLE
    A center bore hole is the hole on the inside of the wheel which is 120mm for the VS
    VB SL/E
    Dec 2008
    VB SL/E
    Dec 2008
    Quote Originally Posted by EDGE3 View Post
    Think about that, the stub pattern is 120mm PCD, where would the wheel studs line up with a 120mm hole in the centre of the wheel????
    Feb 2011
    NEWCASTLE
    The center bore isnt the actual size of the bloody hole I know that,what Im saying is that halfway from one stud to halfway to the furthest stud is how you measurer the center bore which is 120mm for a 5 stud pattern.This part of the wheel is called the center bore.
    VT Acclaim Wagon
    Oct 2008
    I didn't mean to start WW1V but the center bore I was referring to is the hole that sits over, (or locates on) the bearing hub. Bear gave the size as 69.5 for the VT and I believe the VS is the same except for the part the brake disc locates on which is larger. Pax. Maybe should have simplified it by saying "the hole in the center of the wheel"?
    Feb 2011
    NEWCASTLE
    Thats ok mate we dont mind a bit of arguing on here,the way they determin the center bore is they use pythagores rule which is measured halfway from the furthest stud holes, and the hole in the wheel would then be about half of that size.I know its all technical jargon but your right its easy as just measuring the hole in the wheel,but the size of the hubs and studs are not the same in every car thats why you need to measure it to make sure your wheels can fit onto it cheers.
    VB SL/E
    Dec 2008
    Well you seem to have a different method to the industry because on every wheel web site they list the hole in the centre of the wheel as the centre bore.
    Don't shoot me, google it and see for your self.
    Feb 2011
    NEWCASTLE
    If you draw the five studs like on a wheel and then draw a circle starting in the center of the stud and then threw all the five studs so you end up with a circle which is called the PITCH CIRCLE DIAMETOR,thats known as the center bore.
    VR Executive SI
    Mar 2005
    THE PCD is NOT the same as the centre bore. They are 2 separate measurements hence why the centre bore (CB) and pitch circle diameter (PCD) are listed separately.
  15. #15
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by VR38 View Post
    Pre VE is actually 69.7mm not 69.5.
  1. Replies: 0
    Last Post: 28-12-2010, 05:20 PM
  2. big bore without the drone?
    By jonboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2010, 02:05 PM
  3. buick 3800, on center or off center?
    By DryftKult in forum V6 Development And Modification
    Last Post: 03-12-2008, 06:23 PM
  4. Forum Bore 'em
    By FusionX in forum Jokes/Humour
    Last Post: 23-09-2008, 11:17 PM
