Results 1 to 7 of 7
Thread: Tyres
    VT Acclaim Wagon
    Oct 2008
    Default Tyres
    Will the VT V6 Commodore wagon always at 1800/1900kg gross weight handle ok with Bridgestone R623 205 x 70 x 15 LT radials? I am not a racer, nor can I afford to turn my tyres into smoke. Looking at highway and suburban use. Anybody?
    VX Executive
    Mar 2011
    i dont see why not as you only have the stock 15"S. as long as the tyre isn't to hard it should handle fine in any conditions.
    VT Acclaim Wagon
    Oct 2008
    Thanks for the reply. They should not be too hard as they are near new. Fitted to a vehicle sold new in the last couple of months.
    VX Executive
    Mar 2011
    yeah so they should be all sweet as they would be a family tyre to suit family type cars like commodores etc. and as your not hooning around they should last.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    that weights roughly what my car sits at, you should be fine, only issues i found with that weight which you may not have thought of, is i started wearing out tyres quick in the rear on the inside, as the weight through the camber out
    VT Acclaim Wagon
    Oct 2008
    Lufkin, I understand what you are saying but I beat that by putting new genuine GMH LPG coil springs in the rear. My old springs were sitting like I had super lows installed. the wagon sits like a new one now. High in the rear. Hopefully, no camber problems. The other reason I did it was I installed a Hayman Reece 2100kg towbar. It weighs about 45kgs on its own, maybe more.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Being a light truck tyre they will be stiffer in the sidewalls than a passenger tyre, so you will get a harsher ride. They wont grip as well as a passenger tyre but will take longer to wear out. It might be a good idea to talk to someone from your insurance company before you put them on.
  1. [SA] Wanted - 215/60/16 tyres x 2 or 17" rims w/good tyres
    By Textavs in forum Swap / Wanted to Buy / Trade
    Last Post: 01-02-2011, 05:45 PM
  2. WTB: Cheap set of 18 or 19 inch rims - tyres or no tyres...
    By Timzo in forum Swap / Wanted to Buy / Trade
    Last Post: 07-04-2008, 10:56 PM
  3. Tyres.......?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2006, 10:08 PM
