So I'm going to buy a new steering wheel for my car and before you ask, yes i've been to wreckers and looked around and naturally there are hundreds but they're all just as worn as mine. I don't want a silly aftermarket one either, i want just a stock one and I already know where to get one brand new for $100, genuine holden.
So my question is, do I need to be careful of anything when dismantling the old one? Like, airbag etc? Is it easy to put the airbag back in and do i need to have it reset again or something? or is it basically just unbolt the old one, unplug the airbag, transfer everything to the new steering wheel and bold back on?
All thoughts are appreciated
You may need to disconnect battery when doing it, I can't remember the correct procedure.
Definitely don't want it blowing up in your face.
people say wait 30 mins as a precaution for the airbag and some people say you dont need too... personally i'd wait the 30 mins just to be safe
after that do what you want but be carefull
yeh i was gonna do the same thing and was also wondering about the airbag, but where are u gettin one for $100???
Do you have the correct torx socket to remove the steering wheel bolt?
SRS disable
disconnect both + and - wait 10 seconds
this is from the manual
it's triggered by a AC siginal
excellent!ye don't worry i have all the torx tools.that's not a problem. um for the steering wheel for $100, go to the holmartholden website.they're about 5 mins away from me so i'll just pick one up lol
Think only VE has the torx bolt but its Sunday and Im still half asleep.
As said dc the battery and also pull the SRS fuse just to be safe.
In the back of the steering wheel theres 4 slots, stick a flat blade screwdriver in there and twist it to release the airbag. Turn the wheel 90 degrees so the slots are at the top.
Unplug the airbag and the horn connection and place the airbag in the passenger footwell or somewhere safe facing up.
I think you have to unplug a couple of things the allow removal of the wheel not sure, its Sunday blah blah blah
Now an important point here !!
Before removing the wheel make sure the wheels are straight and the steering wheel is level. Remove the wheel by pulling at it left right left right etc to wriggle it off. Under the wheel is the clockspring, DO NOT MOVE THIS FROM ITS CURRENT POSITION!! If it gets wound around even once without the steering wheel on it will break when you turn a corner. It must stay centralised.
Another point is do not give the car power and turn the ignition on without the airbag on or it will log a code that will not clear itself.
Do all this in reverse to fit the replacement wheel.
Have fun.
Silver Certified.
lol now you've worried me lol.um it does have torx screws,i've checked that already.well...maybe i'll go to a wrecker and practice first hahaha
Cool I did a commo wheel the other day that didnt have torx but cant remember what model it was I thought it was VY dunno...
Silver Certified.
lol no probs.i won't be doing this for a couple weeks coz i got rego and insurance to pay for,but i'll go to the wreckers and have a play and then do my own and i'll let you know how it goes.thanks for all the info.it'll definitely help
