Results 1 to 12 of 12
Thread: Have I bought the wrong this?
    Calais VX II 3.8
    Oct 2010
    Default Have I bought the wrong this?
    Hi,
    I have been having some issues with the temperature gauge in my VX2 Calais, and purchased what I thought was the right sensor. From the picture it looks like the one in my car near the thermostat. Champion Coolant Sensor CCS26
    However, it doesn't have the right sized thread, and the electrical connectors while close aren't a match. I note this part is recommended for many cars, and was wondering did I need to buy some adaptors to make the thing fit, or did I get the wrong thing all together?
    Any advice?
    Thanks
    Tom
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Did you go through a catalogue and find that that was the actual right part for the car? Or just guess based on what it looks like?
    2 minutes on the Tridon website told me that you need
    TCS070 Coolant sensor
    Terminal term-100
    Features Thread - 3/8 - 18 NPT
    Spanner - 19mm
    Replaces original black part.
    Repco or Bursons should have the part.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Yep, that's the wrong coolant temp sensor. Why not just get a genuine one from Holden at approx $20.
    Calais VX II 3.8
    Oct 2010
    I rang Holden before I got this one. They quoted $80.
    I didn't do a visual inspection for the part, I looked up the sensor is listed on the champion website MOTOSPECS automotive aftermarket products - incl brakes, suspension, transmission & electrical as for a a vx commodore 2002 ... among many other brands. What I am trying to establish is, if I made a mistake reading their website they do list this as a coolant temperature sensor for a vx commodore. If it's not actually a coolant sensor for a vx commodore I'll ask for a refund. If somehow or other I've bought a part for another part of the engine by mistake I'll wear the error.
    The Tridon one looks exactly like the one I need. Thanks for that.
    So they have sold me a coolant sensor that they list as for my car or have I been misled? I've heard somewhere there are two sensors in the engine, one for the ECU and one for the dash, I thought perhaps I may have bought the wrong one. It's listed as being suitable for heaps of cars that's what made me curious.
    Here's the listing from the champion website.
    CCS26 COOLANT TEMPERATURE SENSOR
    HOLDEN
    COMMODORE 1980 - 1981, VC, 6CYL 2.8L BLUE CARB
    1984 - 1986, VK, 6CYL 3.3L BLACK CARB
    1984 - 1986, VK, 6CYL 3.3L BLACK EFI
    2000 - 2002, VU UTILITY, V6CYL 3.8L ECOTEC MPFI
    2000 - 2002, VX/VU, V6CYL 3.8L ECOTEC MPFI
    1997 - 2000, VT, V6CYL 3.8L ECOTEC MPFI
    1995 - 2000, VS, V6CYL 3.8L ECOTEC MPFI SQUARE DESIGN : 2 LAR
    vs commodore
    Oct 2009
    Tamworth NSW
    I just checked it out,the CCS26 sensor is definitely listed as the right one for the ecotec on that website.It also shows that the CCS26 sensor was still used used on the VT,VX ecotec engines.If it doesnt fit then Id be contacting the place you bought it from.I agree with the post above that recommends using a genuine holden sensor.I wont bother with anything else when it comes to engine sensors.Genuine parts will last for ages,usually a lot longer than some cheaper aftermarket parts..
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You purchased a coolant temperature sensor which connects to the engine management system. What you need is a temperature gauge sender which connects to the temperature gauge and is also listed on the MOTOSPECS web site.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by BlackVXGTS View Post
    Not on a VX V6. They do not run a separate coolant temp sensor AND sender like the earlier VS's. They only run the 1 coolant temp sensor which is also utilised for the temp gauge signal.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by tairvine View Post
    Far out! Mate ring another dealer if there's one not too far away or maybe even look online like ebay etc.
    I bought one approx 1 month ago and i know I certainly paid no more than $30 for it.
    Calais VX II 3.8
    Oct 2010
    Quote Originally Posted by cander24 View Post
    That makes sense, I'd read that maybe they did, but I looked and looked no sign of any other sensor. Seems they are listing the part I bought incorrectly. It couldn't work on the VT VS and VX.
    Calais VX II 3.8
    Oct 2010
    Suttons Arncliffe, in fairness it was $76, I rounded up. I would have assumed the dealers had standard pricing, maybe a bit of a difference from store to store but more than double is this normal? I would have never thought to ring multiple Holden dealers.
    Aug 2004
    My mistake. I knew that this was the case for the Gen III V8 engines but didn't realise that it was also the case for the V6s. Should have followed my own advice and not commented on V6 matters !!!
    Calais VX II 3.8
    Oct 2010
    Eziauto solved the problem. Apparently there is an issue with the motorspecs website, spews out wrong information. the one I need is Champion Temperature Sender CTS147
    Which at least looks the same as the Tridon TCS070.
    I am sending the wrong one back for a swap. Thanks all for the help.
  1. Just bought a 06 SV6
    By Davec in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-11-2010, 12:08 AM
  2. Another Wrong colour fluid in wrong chamber?
    By just_vt_problems in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 07:14 PM
  3. Just bought these..
    By Bobski in forum Car Audio
    Last Post: 27-12-2009, 06:23 PM
  4. just bought a VL
    By born2mosh in forum VL
    Last Post: 25-09-2007, 09:40 PM
  5. I Just Bought A Vk
    By Jase VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-09-2003, 04:00 PM
