Results 1 to 4 of 4
Thread: Seat Replacement
    VX lumina
    Apr 2007
    Callington SA
    Default Seat Replacement
    I have a VX Lumina and the drivers seat needs replacing, it has the airbag in the seat will a vy seat (with airbag in seat) fit?????
    GSXR1000
    Apr 2010
    WA
    Yep, should be fine.
    May have to look at splicing wires or something, not sure if it's a direct swap, but should be with minor adjustments if it's not direct.
    VT Series 1 V6
    Jan 2008
    If you take the plastic mouldings off on the door side (the ones covering the seat rail and bolts) you should be able to see the wiring connectors. In a VT the connectors are clipped to the side of the seat rail, should be the same on other models maybe. If so, then you can then check the plugs and make sure the VY seat has the same fittings.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Probably best to get a VX Lumina seat if you can so your trim all matches..
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  1. Project RejuVeNate~ Front passenger seat changed to drivers seat?
    By Budmulla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2011, 06:36 PM
  2. VE Omega Seat Trim Replacement
    By mercho in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-10-2010, 07:56 AM
  3. ECU/BCM replacement, and remote key replacement/ignition replacement
    By skunks.monks in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:08 PM
  4. seat replacement
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-10-2009, 01:38 PM
  5. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
