Just bought my commonwhore VX, 1st car... chuft AZ! I have 2 subs and an amp ready to rock and roll. So as i was cleaning the car giving it a bit of a spruse today... i pulled out the head unit to find no rc leads... annoyed i found this wondeful website, and the threads go on and on about the issues people have with changing an after market head unit into the car with reguards to the controls on the steering wheel.
Are there any guru's out there that can pin point a programmer device (No idea what its called) for the control that will work with this paticular model car, and if so a head unit that will easy match this program. preferably with ac connections as well as aux if possible.
Jarred.
A Clarion headunit and a 'CAT-10' do the job for me - steering wheel controls work excellently. I have mine set-up hard-wired, not with the IR interface.
cheers
Senator 300 - the CLASSY C4B!
LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
