Iv tried every possable way to remove the gear knob off my VT 5 speed.
How the hell do you do it.
My gregories manual says nothing about it
Check out My SV8 One Tonner
You can get a lot farther with a kind word and a gun than a kind word alone
It shouldv'e screwed off. You HAVE tried turning it, haven't you?
TORANAS FOREVER!!!!!
I thought there was a little pin under the front of it..where your fingertips touch......( I might be wrong though...)......
ive tried turning, pulling, exploding and even calling the special forces.
NOTHING WORKS!!!:b:
I know how you feel. My VS has one of these stupid knobs as well. What a shit set-up.
I have tried everything to get the bastard off!!
i had the same problem until i one day removed (lifted it up like you would a skirt)the shifter surround boot. i then inserted a flat bladed screwdriver between the step in the shifter and the bottom of the knob and levered it up. once you do it the first time, it's not so hard the second time around.
Last edited by VT-565; 20-09-2005 at 05:41 PM. Reason: to explain myself a bit better...lol
Hmm I cant help u much, if u had asked how to remove an auot shifter thats another story...
anyway had a squiz in the haynes, wasn't too helpful but this is what it said if its worth anything:
1. release each of the eight plastic clips which secure the gearshift lever rubber boot to the console.
2. Grasp the lever and the gearshift knob firmly. Move the knob back and forth while pulling upwards on the boot. Remove the knob/boot assembly from the lever.
Good luck![]()
Give my idea a crack......it'll McWork i bet you
it better Mc%$&#ing Mcwork.
Otherwise ill scrap it and buy an auto
Check back later, VT possably going cheap
as low as $5
LOL
OK. Its a 1 min job
For all those out there who need to know.
You will need...
1x large flat head screw driver (bout 8mm across face)
1x pais of scissors
1x wire zip tie
Procedure
1. carefully unclip shifter boot up off console, after you get a corner up it will just pop out with a little force.
2. pull boot all the way up over the gear knob. (like a female flashing)
3. slip screwdriver directly under bottom of knob and twist wrist, POP off it comes.
4. Cut existing zip tie holding boot onto knob.
instalation is reversal or removal procedure no forgeting to replace zip tie.
I dont think it comes much clearer that that
if you dont mind... how does one replace the auto shifter?Originally Posted by Julie
buy me an auto VT for my birthday and ill tell you.
Search around, I found a few
It's all explained with pics here: How to install a chrome shifter button in your VT/VXOriginally Posted by ZER0
chevy.......... If you don't mind I would like to post your explanation of how to remove the gearknob into the how to section![]()
no problem with that as long as i get royalties
LOL only kiddin
yea thats fine by me
