Results 1 to 13 of 13
Thread: stupid water pump
    VX SS II 5.7 6spd
    Apr 2010
    Unhappy stupid water pump
    Just some advice or info needed guys, had the water pump changed on my vx ss in December, now its leaking again. Is there a gasket or sealant that I can put on? It started leaking after I drove.from Melbourne to wagga wagga. Or is it possible it wasn't tightened properly when put in?
    Cheers, Kosta
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Hey Kosta ,it could be a faulty water pump I had 5 water pumps replaced in a row b4 I finally got one that worked properly.Go and have it replaced again because it will have warranty on it and you shouldnt have to pay for it.
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    The waterpump kit should come with two new gaskets. Did you go genuine of aftermarket? Get the place you got it replaced at to do it under parts warranty, and then get them to check the rest of the cooling system out once the pump is replaced to make sure everything else is working as it should.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vs commodore
    Oct 2009
    Tamworth NSW
    Genuine water pumps are more expensive than the cheaper ones, but they are worth they because it will last heaps longer than most cheap ones,(thats if the cooling system is looked after properly etc).I know guys who have gone through 2 or 3 cheap water pumps to one genuine pump,so it ends up costing more in the long run than it would have for a new genuine pump.Ive found this is usually the case with most "cheapie" aftermarket parts,especially the 3 ignition coils on V6's, and cheapie crank angle sensors.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Run a socket over the pump holding bolts, just in case they are a bit loose.
    GM GEN3's Avatar
    GM GEN3 is offline GM GEN3
    legs ATM
    Sep 2008
    S.A
    Take it back i would i had mine replaced cos of leak haven't had a problem since mine was only cheap like 250 or some thing like that
    VX SS II 5.7 6spd
    Apr 2010
    thanks guys, i bought the pump myself, cost me $210, had a mechanic fit it, just really is annoying that its already shat itself, any other good brands besides from original gm?? got a trade price quote from autobarn for $235
    VT Acclaim Wagon
    Oct 2008
    I am seeing a stack of these on ebay from just over $20 to $49. Buy a couple and you are still way in front. Fitting is so easy it is stupid. I did my one on the side of the road with a few spanners and a scraper to get the old gasket off. probably pay to put a smear of gasket silastic on the new gasket before installing. If you want to look at the ebay items, here 'tis...VT Commodore V6 water pump, Car, Truck Parts items at low prices on eBay.com.au
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Yeah I got one for $35 and fitted it in half an hour.
    Piece of cake to do.
    Can't believe some cost over $200.
    Just goes to show how much mark-up there can be on these parts.
    VX SS II 5.7 6spd
    Apr 2010
    im going to replace it myself this time, but its a gen3 so i havent found one that cheap, all around 150-260$
    GM GEN3's Avatar
    legs ATM
    Sep 2008
    S.A
    If you can get one for 150 get it mine cost me over 250 it doesn't look hard to do the worst thing is getting the dam belt back on right lol
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by GM GEN3 View Post
    The belt ain't that hard to get back on.
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    i replaced mine on gen3 a while ago, get ready for your radiator to go soon! how many k's has your car done? i bought this water pump and have had no problemshttp://cgi.ebay.com.au/Holden-Commodore-VT-VX-VY-VZ-Gen3-V8-5-7-LS1-Water-Pump-/250799722280?pt=AU_Car_Parts_Accessories&hash=item 3a64d40f28#ht_1629wt_907
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. [VIC] FS: VN SS V8 Heads, V8 water pump, V8 oil pump
    By dans_vz in forum Parts And Other Items For Sale
    Last Post: 22-02-2011, 06:37 PM
  3. Water Temp/Water Pump?
    By Fred 96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2010, 01:58 PM
  4. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  5. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
