Results 1 to 7 of 7
Thread: Faulty computer in VX Calais?
    VX Calais
    Mar 2011
    Default Faulty computer in VX Calais?
    I have a 2000 VX Calais that has just recently started doing the following at random times (either when I start the car, or when I am driving) - It happens almost on every trip now and is occuring more frequently:
    - Engine, ABS, Trac Off, Oil Light all light up (Oil is fine)
    - I lose Air Con (with a small X on the screen), Power Steering and Power Brakes.
    - No or stuck gear indicator, Temp guage sits at Cold, speed/tacho/fuel OK.
    Car still drives OK apart from the above, would you be safe to assume the computer is at fault here considering it is effecting other systems? If so what is the cost? Or should I just take it in to a dealer? I am looking at replacing the car within the next few months so dont want to spend a fortune.
    Any help greatly appreciated.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be a faulty ABS module, that can cause some weird things. Best thing to do is get it diagnosed. Disconnect the ABS module connector and see what happens.
    MY RIDE
    VT Calais
    Mar 2009
    SA - Victor Harbor
    disconnect abs module, you should then have lowtrac, abs and trac off, light turn on, but everything be fine, if so, abs is dead
    VX L67, ln106 hilux, xr600r
    Jun 2009
    qld
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    your bcm (body control moduel) controls all of those systems this could be the problem your ecu manly controls the engine
    VX Calais
    Mar 2011
    thanks guys, wiggling the ABS harness will clear the oil light, as does disconnecting it. The others stay on. I have tried cleaning the contacts with contact cleaner but no difference.
    my only concern is the air con (compressor)/power steering and brakes all stop working when this happens, so could it be BCM as Burnout124 suggests?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I remember reading a post on here years ago by Doctor Bob who was a Holden technician and knew a lot, he said if the oil light goes out when the ABS module is disconnected then the module is at fault. I suggest you go to Holden and get them to check it out rather than buying a module or BCM and perhaps wasting money.
    MY RIDE
  1. faulty calais air con
    By luxury motoring in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2012, 08:11 AM
  2. VZ Calais - FAULTY REVERSE PARKING SENSORS!?
    By VZCALAIS190 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-02-2011, 08:13 PM
  3. Faulty trip computer
    By scallionman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-10-2010, 08:40 AM
  4. faulty computer draining power
    By VL Berlina 5speed in forum Electrical Wiring / Questions
    Last Post: 16-03-2009, 03:41 PM
  5. VP Calais Trip Computer
    By Rattus in forum Electrical Wiring / Questions
    Last Post: 07-07-2005, 03:05 PM
