Hi Guys,
Hopefully i can get some help with my 97 VT.
Once the engine is warm it will miss and fart and carry on, occasionally stalling. Not sure if its just a coincedence or not but it seems to only stall going round corners or roundabouts![]()
What I've replaced:
Cam Angle Sensor.
Crank Angel Sensor.
Plugs.
Leads.
Coil Pack.
Fuel Filter.
Fuel Pump.
The problem is still therewhen I get the fault codes it comes up with #49 - Cam Angle or Crank Angle Sensor (signal Intermittent) any suggestions on what that could be ??
Cheers Guys.
I've heard the magnets that the crank angle sensor uses to read can come detached.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
Check ur purge valve near the throttle body. If that has come loose it will stall. But it sounds like it's the fault
How do I know if the magnets that the crank angle sensor uses to read have detached ?
The purge valve is still attached.
Any Idea how to fix fault code 49 ?
You have to remove the timing cover.
This post shows you what you are looking for - VT rough idle, slight miss IDEAS!!??
Thankyou
Hopefully I get the bucket of shit fixed soon.![]()
If that's not it, try your DFI module (the board that the coils seat into).
Cheers, will let you know how we go.
