Results 1 to 6 of 6
Thread: VT ls1 recall
    VT SS 5.7
    Mar 2005
    Goulburn
    Default VT ls1 recall
    When the first vt ls1 were released i was told holden pulled a recall on them to fix piston slap
    Just wondering how did holden fix the problem? new motor or somthing else?
    Real cars don't power the front wheels, they lift them
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VT SS 5.7
    Mar 2005
    Goulburn
    Cheers soop , So if i was to chase down a vx ls1 motor will it slip in my vt ss and wirer up the same way or is there a diffrence?
    Nov 2008
    Smithton, Tasmania.
    If its a Gen3 VT it will bolt straight in and wire straight up. VT 2 and VX 1 are identicle motors.
    VT SS 5.7
    Mar 2005
    Goulburn
    No worries cheers mate, just 1 last Question mate. do you think it would be worth chasing down a vx ls1 and putting it in my vt ss or should i look more at finding a 6ltr to slap in
    Nov 2008
    Smithton, Tasmania.
    If you're keen.
    You can by LQ9 Gen3 Iron blocks which have 4" bores. So with an LS1 crank it will make 6ltrs. It will accept 241 LS1 heads and everything associated with them. It will bolt right in and wire straight up in place of an LS1 but you have 6ltrs as a minimum.
    Going to a gen4 will need a bit more work and wont wire right up.
LinkBacks (?)
  1. 09-04-2011, 11:19 PM
  1. VE ute recall
    By ssv 08 ute in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-09-2010, 03:32 PM
  2. GSP hub recall
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2008, 11:12 AM
  3. Yes! - Another VE Recall
    By SV6Sean in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-11-2006, 05:45 PM
  4. VZ Recall
    By RVN 355 in forum The Pub
    Last Post: 13-06-2005, 10:14 PM
  5. VX 2 Recall
    By v8bike in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2005, 05:08 PM
