Results 1 to 7 of 7
Thread: 00 VX Commodore -fault code 0012 normal operation -car still stalls turning right
    commodore vx 2001
    Feb 2011
    Post 00 VX Commodore -fault code 0012 normal operation -car still stalls turning right
    Hi,
    Our problems started off firstly need the CAS replaced, followed by the Fuel pump & filter. Now car is still stalling turning right!!!
    Checked codes yesterday but fault code shows: 0012 Normal operation. turning left is fine, but turning right, the revs fluctuate and car stalls. Also after being driven for long periods, will just turn off.
    I was wondering if anyone had any advice or tips to point us in the right direction. Any advice would be greatly appreciated....
    Thanks
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Might sound stupid but how is your power steering fluid?
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    commodore vx 2001
    Feb 2011
    vs commodore
    Oct 2009
    Tamworth NSW
    Id check the battery clamp and the battery terminals.If the battery is moving around slightly when cornering,then it can cause bad connections in the wiring around the battery terminals etc,it might be worth checking if theres any movement there,and if theres any dodgey looking connections.
    commodore vx 2001
    Feb 2011
    Hi, Thanks, my partner checked the battery etc, all good!! He also removed the throttle bottle & gave it a damn good cleaning.... It was quite thick with black sludge, the only way to describe it... Running much better now, but still stalling right!! Going to give it a large gut full of fuel to see if it's possibly something in the fuel assembly. Still would love any other advice!!!
    VX Executive S2
    May 2006
    Frankston South Vic
    If this stalling issue just started check the wiring to CAS and fuel pump, start car, and then wobble wiring to these and see if you can duplicate fault.
    If you replaced these parts to try and cure stalling fault then I would start car and wobble wiring to module under ignition coils and wiring to back of alternator and battery terminals and wiring to starter motor(the main power leads) and wiring under relay/fuse box.
    One we had 30 years ago (from the twilight zone) only stalled when turning left was a loose plate inside the battery. so you could undo battery clamps and give battery a shake while engine idling
    VT Series 1 V6
    Jan 2008
    Stalling on right turn is a classic symptom of a fuel pump on it's way out. Since you recently changed it, I would first check that the new pump was installed correctly (don't assume it was, check it), and if so, I would be looking to maybe get another fuel pump, or try and find a good one you can borrow to test. There have been a few instances on this forum where a new fuel pump has turned out to be faulty or not correctly installed.
  1. 5L V8 Stalls during normal driving
    By jon_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2010, 11:22 AM
  2. Fault Code Reader for VT Commodore
    By greyingwiseman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2009, 09:27 PM
  3. VR series 2 commodore - fault code 47
    By Bearman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2007, 08:29 PM
  4. Electric Antenna Operation - Normal Or U/S
    By monarols71 in forum Electrical Wiring / Questions
    Last Post: 09-11-2006, 08:06 PM
  5. ex cop vz interior light, how to restore to normal operation?
    By gibbo in forum Electrical Wiring / Questions
    Last Post: 07-08-2006, 09:34 AM
