hi, i just had my vx series 2 S pack Auto on a power run the other day and it only gave me 105kw at 174km/h i was just wondering if this was normal, i looked up the specs of the ecotec engine and it said it had 152kw, is this from the rear wheels or the engine.
Thanks
from the flywheel
you have 105rwkw
the 152kw is the flyhwheel
im assuming you have no engine mods or anything? cause i worked out you car has 152 kw at the flywheel which is standard :P
Yeah it's just standard at the moment, want to do a cold air intake, bigger throttle body and extractors
105 is a good figure for a stock ecotec auto
tuning done by THE1 A+++++ tuner
And powering it by MACE
Build it to handle the MANG
i wouldnt bother with intake... go roller rockers $600 give or take and flash tune $350
Well to be precise, my motor stock was:
Starting Power: 109.8Rwkw
Then after i did exhaust/extractors + lukey air filter it was:
Current Power: 115.5Rrkw
dont know what my old ecotec was standard but after pacies, two high flow cats, twin 2.5 until first box then 2.5 single rear resi made 118rwkw's.
this goes both ways, whats point of OTRCAI if you are restricted by internals of engine? the stock OTR is more then enough for a v6, sure it looks shiny and may give a different sound but its just a placebo effect, put it on a dyno and you will see you got nothing more from the fancy OTR than you did from stock
I noticed a difference with my aftermarket CAI, the throttle response and power was marginally better, this was mainly up in the higher RPM range as well mind you (this is my opinion)
People can say that certain things do nothing on cars, and others with say they do. But without solid proof of if it works or not and if it hasn't been tested on more than just one car, don't believe a word the say, or make your opinion after researching it a bit!
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
It was my understanding that 152kw was at the motor in the factory with nothing being driven by the motor like alternator Etc what's a standard manual do at the wheels??
