Results 1 to 1 of 1
Thread: efilive pro with obd2 cant get heatbeat help !!
    southaussie's Avatar
    southaussie is offline Family Guy
    VT Executive 97
    Mar 2011
    Tranmere, SA
    Default efilive pro with obd2 cant get heatbeat help !!
    what am i doing wrong? i just got this cable off the net and it is in the diagnostic plug, and my lappy, and im running the efilive pro v4 registered, i have selected the gm-vt6 xml and chosen the correct com port whick has been assigned to the device and NOTHING...
    screen as follows
    31:33.642: Initialising...
    31:34.207: Opening COM4 8228,8,N,2
    31:34.469: Ready.
    31:39.002: Start macro: Engine data and DTCs: DATADTC
    31:39.000: Synchronising ALDL communications...
    31:39.000: Waiting for heartbeat: $08,$55,$A3
    31:39.000: Waiting for Aldl bus silence of at least 50ms...
    31:39.151: Com timeout: Expecting frame header byte
    31:39.163: Synchronising ALDL communications...
    31:39.163: Waiting for heartbeat: $08,$55,$A3
    31:39.163: Waiting for Aldl bus silence of at least 50ms...
    31:39.314: Com timeout: Expecting frame header byte
    31:39.325: Synchronising ALDL communications...
    31:39.325: Waiting for heartbeat: $08,$55,$A3
    31:39.325: Waiting for Aldl bus silence of at least 50ms...
    31:39.476: Com timeout: Expecting frame header byte
    31:39.489: Stop macro: Engine data and DTCs: DATADTC
    31:43.789: Check vehicle interface...
    31:43.794: Waiting for Aldl bus silence of at least 50ms...
    31:43.844: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    31:43.865: Max232 interface detected OK
    31:43.866: Scanning for heartbeat and chatter frames...
    31:43.866: Waiting for Aldl bus silence of at least 50ms...
    31:44.017: Com timeout: Expecting frame header byte
    31:44.032: No chatter found
    with i/o on
    10:30.102: Check vehicle interface...
    10:30.108: Waiting for Aldl bus silence of at least 50ms...
    10:30.158: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    10:30.158: Start writing frame
    10:30.158: Send: $FF,$55,$AC
    10:30.159: Finished writing frame
    10:30.159: Wait 10 ms after writing, before reading...
    10:30.169: Start reading frame
    10:30.174: Aldl frame header byte: $FF
    10:30.174: Aldl frame length byte: $ 0
    10:30.174: Recv: $FF,$55,$AC
    10:30.174: Finished reading frame
    10:30.174: Max232 interface detected OK
    10:30.174: Scanning for heartbeat and chatter frames...
    10:30.174: Waiting for Aldl bus silence of at least 50ms...
    10:30.225: Start reading frame
    10:30.326: Com timeout: Expecting frame header byte
    10:30.384: No chatter found
  1. Vx 5.7 obd2
    By 2001VX5.7 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2010, 11:03 AM
  2. Obd2 vz ss
    By stansvetec in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-12-2009, 03:22 PM
  3. OBD2 Scanner
    By ahmedomnnea in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2009, 08:25 PM
