Can you fit a vy cluster into a vt-vx and make it work ?
Modifying a car is like a drug once you start you cannot stop
Holdens if your not in one your behind one
Simple answer, no. None of the wiring will match up, and it works completely different to the VT/VX clusters
Ok cool thanks for that
unless of course you run extension cables, rewire the whole thing and have the cluster sitting on your lap!!!
