So just got my vx back from the mechanic and apart from a host of other problems that he says it has, he says the engine mounts are worn and need replacing.
I would just want to find out if anyone knows whats involved with replacing them? Should they need replacing, its only 10 years old after all? He reckons that that sump is closer to the ground as a result, but looking underneath it doesnt look any lower than normal too me. With the quote of $500 he gave me to replace them, I just want to make sure if its something that requires the urgent attention he seemed to say it did and if that price seems right too.
Any help would be really great guys.
mate 500 is a bit more and for the sum it should be ok as long as it doesnt touch the k frame. a quick test will reveal if the mounts are in good condition by looking underneath and check the pin in the mount if its touching. other way is to put car in d and with foot on brake peddal give it little gas and check for excessive movment frok the engine.
Getting ripped off mate my ss one's are heavy duty they are 100 each and got them fitted for 30 bucks all they do is unbolt them jack up the motor and fit the new one's it takes like half an hour at most mate i would shop around at that price
I just dont trust them to be honest. I only got the vx a week ago and it was due for a service so I took it in. I have all the records of the previous work done on the car.
One of which was a new radiator and coolant about 2 weeks ago, a week before I bought it. The same mechanic also told me today I was in need of a coolant flush. That makes me wonder.....
Gen3 and V6 engine mounts are completely different. Both the mounts themselves and the procedure to change them
In my shop we charge $380 supply and fit. That's using Mackay brand non hydraulic mounts along with the trans crossmember mount at the same time. They last for 5 years or so where as genuine hydraulic units will fail repeatedly ebery 2-3 years and cost way more.
VYII Calais L67
I had mine replaced last year with a pair of genuine Holden ones and paid $490 which included the mounts. Mine started knocking on the subframe at about 170,000 klms .
We've had ours for 16 months and just love the vehicle and still can't believe the performance and the remarkable fuel consumption, 43plus on the highway with the hiclone, extractors and the megaflow exhaust system.
shop around, I done my ones a couple years back and it was a a$$hole of a job.
if you what to check if there stuffed, have a look under the car and if the sump is lower then the cross frame there rooted.
jack the car up and put it on stands, block of wood under ur sump and jack it up,
look at the left mount, is it cracked? if not then dont worry
mine are starting to wear also (02 VX equipe 75,000kms) and i will be doing them next service at my usual mechanics for $250, i would think for a v6 your getting really ripped off mate
Well we got the mounts done on mine (98 VT Exec, at the time 410,000km). One was shreaded completely and the other badly worn. Mechanic just did it with the normal service, About $150 for the mounts and not sure what labour was cause it was just with the normal service, but wouldn't be more than $100. So anything more than about $250 rip off in my books.
$500 is just nuts.
It is semi-urgent, cause the engine was bouncing around in the bay lol. Basically you'd rev the engine would lift and crash back down. Depends on the degree of damage.
I would put it top of you list of things to fix, but it's not something you HAVE to do tomorrow, just take it easy with the car.
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
Hi Guys,
Just replaced the mounts on my son's VX yesterday. What a fiddle. Used the solid rubber replacements on the grounds they would last longer (and they're cheaper!). The drivers side one is not too bad (although the nut at the back is a quarter of a flat at a time) but the left one needs the aircon off, and the mounting block removed from the engine. The good news is that makes it easy to line up the bolts when you refit. If someone will do it for $150 labour,let 'em.
The mechanic is probably right saying that they are worn (if they haven't been replaced before). I have done so many VT/VX V6 engine mounts at work that its getting easier. Just make sure the sump isn't hitting the K frame and that the pins that go through the engine mounts are not touching the k frame either. Also don't get them genuine. We always buy replacements from Repco.
10 years old they're shot for sure.$500 is too much but contrary to general opinion i suggest giving some thought to still using hydraulic mounts (holden used them for a reason )though they are not likely to last as long as aftermarket solid mounts.my vt has done over 350,000 ks and has had the mounts replaced twice.some mechanics say that the a/c needs to be removed as part of the job but mine hasn't been removed either time (maybe just lucky,i would'nt know for sure )
