I had a problem with the indicator on my VT II. The indicator would not go back to its original position after turning. The auto electrician told me that a new combination switch (with cruise control) will need changing at a cost of $150. After I read some of your comments especially the detailed procedure prepared by Ozzie (I think), I was able to change the switch (stalk) in about 25 minutes and at a cost of only $45. The new switch does work really well but sometimes it does not move up to indicate that you are about to turn left. Any help on this problem will be much appreciated. Thanks
