Results 1 to 5 of 5
Thread: Transmission Vibration
    vt ss
    Feb 2010
    Default Transmission Vibration
    I recently brought a series 2 vt with a LS1 and it has a vibration coming from the transmission I think . i had a 98 mdl 5ltr witch i smashed so i swapped out the tailshaft thinking it could be a uni or a center bearing and it still has this vibration. it only does this after driving for 10 minutes or so and only when cruising and backing off ,it disappears under acceleration. the transmission shifts fine. according to the tag under the bonnet it is a M30.
    Any help would be appreciated
    One other question as well, both the 98 and 2000 vt tags say that the transmission is a M30 even though one is a Ls1 and one is a 5.0ltr are they the same or is the bolt pattern on the bellhousing different ,if so are the bellhousings interchangeable like older transmissions e.g trimatic.
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    As above, I'd be inclined to think it's either the engine mounts are saging / cracked, or the transmission mounts are sagging / cracked.
    Worth a look before swapping out the gear box.
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    vt ss
    Feb 2010
    No i hav'nt but was thinking that the other day and I dont know of a way to check them without installing new ones i did check to see if the engine lifts on one side when reving the engine and didnt notice anything out of the ordinary. i also thought it might be the gearbox mount also .its strange that it dosnt make this vibration until it has warmed up .
    thanks for the quick responce pablo if you know a way to test the engine mounts please let me know
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Check the shift plate/mounting plate for cracks
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
  1. VX vibration and grinding noise... transmission prob?
    By Senna.In.The.Wet in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2010, 08:50 PM
  2. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  3. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  4. Transmission Vibration? M6
    By JMiller in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-06-2006, 12:03 AM
  5. auto transmission vibration in vc
    By marky mark in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-10-2004, 10:19 PM
