Results 1 to 6 of 6
Thread: Engine noise/throttle body
    VU SS 5.7L LS1 2002
    Jun 2010
    Qld, Gold Coast
    Question Engine noise/throttle body
    Hey guys just bought a SS inductions 78mm throttle body and fitted it. I found out that colant ran through the bottom of my orginal one and have bypassed that. Looking on the forums i have seen that people say its just to prevent it sticking with freezing but just wanted to ask as not 100% sure.
    I found my old throttle body the control flap in the middle one of the star screws was loose and the control flap could move around, hopping this is what was causing my accelerater to stick after hard acceleration (or as it was more frequently, burnouts :P)
    I have also found that a tapping/nocking noise comming from my engin bay has stoped, maby it was the losse control flap in the old throttle body?
    The other thing i wanted to say was that in my stock throttle body when i pulled of the colant it came out with a fair amount of pressure, posible that hadent let car sit for long enough but i noticed that the first 2-3 seconds of discharge was dirty/rusty looking and that the metal conection on the bottom of the stock throttle body was cloged with rust. I tryed to blow through it and it woulnt budge!
    I just thought it was worth mentioning, any info would be nice.
    Thanks Toby.
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Why did coolant run through it,the throttle body is part of the air intake,air should run through it not coolant
    VU SS 5.7L LS1 2002
    Jun 2010
    Qld, Gold Coast
    It dosent run through the throttle body as such, it runs through a conection bilt into the bottom of it, rang mechanic and asked and he confermed its to stop it freezing shut in cold climates
    VU SS 5.7L LS1 2002
    Jun 2010
    Qld, Gold Coast
    Bloody car is doing it agian. New throttel body didnt so shit all >.>
    What would be making my car rev to high? or get stuck at high revs.
    Over this!!!!
    VT Acclaim Wagon
    Oct 2008
    VU SS 5.7L LS1 2002
    Jun 2010
    Qld, Gold Coast
    how do i check for that?
    when i open the throttel body manualy its fine....but thinking of that maby i should get a mate to sit in there and pump the pedel for me. It its sticking how do i fix that?
  1. Engine light on after fitting new throttle body
    By Rowenb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2011, 05:51 PM
  2. noise after installing 69mm throttle body??
    By hoofelmuma in forum Mace Engineering
    Last Post: 27-07-2010, 03:45 PM
  3. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  4. engine oil in throttle body area???
    By cpbait in forum LSx Development and Modification
    Last Post: 12-12-2009, 07:03 AM
  5. strange sucking noise coming from throttle body area
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2006, 03:19 PM
