hey guys, i beleive that my diff is going to die and drop off soon cause it clunks so bad constantly and also through gears, so if i buy a new lsd diff for my car with different ratios to my stock one will i need to buy new axles also? i own a vx acclaim if that helps..
thanks guys
Is it IRS or solid
When was the last time you had it serviced m8?
Also check my ride,sitting on HSV R8 19's
" And on the Seventh day ,GOD created Commodores!!!! "
Thats a good question Kunu,maybe it just needs to have some diff oil put in
uhhh i have IRS and i havent had my diff serviced since i bought the car and that was about 80,000ks ago
May be the centre bearing only. You can bolt any IRS diff to your car without changing axles except a Hydratrak lol. If you change diff gear ratio an adjustment will need to be made in the speedo to calibrate it using a tech 2
VYII Calais L67
