Results 1 to 8 of 8
Thread: door clunking
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Default door clunking
    Howdy i have a issue with my passengers door clunking on every bump, its really annoying as passengers say oops i must have forgot to shut door properly, then i tell them no the door is just a POS. i can stop the clunking by putting a bit of a electrical tape on the catch on the door pillar, but that only last a week then clunks again, whats the permanent solution?
    VT
    Feb 2010
    Move the catch on the door pillar. If you loosen it, its very easy to adjust.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by ])R@G()N View Post
    my concern with that was if i made it tighter i would be more prone to breaking handles? i thought there was like a plastic bit inside catch on door that stopped the clunking or something
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    yeah the door striker plate would have had a black plastic sleeve covering it where you are putting the electrical tape.
    I think the only way you can fix it properly is to purchase a new striker plate.
    I have the same problem on my drivers door, so I just went and got some thicker electrical tape, i can't remember how thick it was, and wrap it around a few times.
    The thicker tape lasts longer, I generally get a few months before I need to do it again.
    VT Calais
    Mar 2009
    SA - Victor Harbor
    Quote Originally Posted by mummbles View Post
    cheers mate, did you ever end up getting a quote for a new striker plate?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    LOL, my driver's door is the only one that still HAS the black rubber on the striker, and driver's door is used 90% more than the passengers.
    However, my passengers door doesn't clunk due to the fact that the rubber is gone??
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    If you adjust the door striker inwards fractionally, it will mean that the door is pulled tighter into its aperture and will sit more firmly against the sealing rubber. That might help to alleviate the "clunk", because the door won't have the same freedom to move. Just don't adjust the striker in too far, or the door will have to be slammed every time you close it and the panel might not align flush with the rear door.
    vx custom 600RR
    Oct 2010
    you could buy some clear tubing cut a slit and glue it on
  1. VT Diff Clunking
    By sharpeidog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2009, 10:29 AM
  2. Fun Clunking Times
    By Grennan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2008, 11:15 PM
  3. Clunking, anybody help?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 05:21 PM
  4. help, help, help, help Clunking VX
    By shaun100 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2008, 10:45 AM
  5. Clunking
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:06 PM
