yeh im a noob kinda.
anyway
i installed aftermarket led's into my cluster got them all working nice got a flat battery. chucked the charger on got her going put her back together turned my fog lights on and the dash lights and headlights turned off completely and i could hear a noise from the cluster. sounds like a short but im not sure. any thoughts would be great!
The new LEDs could be buzzing a little or have a bad contact and jumping across the contacts maybe.
how were the LEDs put in? were they just the cheap way (plug and play) type? or did u make ur own circuits? Did u use resistors? ive never heard LEDs buzz but discribe the noise if ya can?
you should never install LED in the dash warning lights
LED lights for dash speed temp fuel tacho is fine
LED's are diodes and the warning lights are activated by cbus it can cause all sorts of warning light problems
like i said it's fine for illumination
handy tip and basic electronics
if you expose an LED to light it will produce 1.2 volts , so feeding an input to an output is never a good thing
any light, the brighter it is the closer you'll get to the 1.2 v so maybe 3 in series will light 1 led but i'm not sure on the milliamps they produce, you may need more
IIRC the red clear LED produce the most volts
google reversed led's or similar if you're interested
