Results 1 to 24 of 24
Thread: How can i improve my VT's handling ?
    VT
    Jul 2010
    Central Coast, NSW
    Default How can i improve my VT's handling ?
    Guys ,
    wanna make the VT handle better , lots of body rolled even when changing lanes !
    how to improve it ? already have new struts , new springs , both front and rear , few new bushes
    looking at rear sway bar but seem to be a BIG job to change it !
    should i get bigger rear swap bar ? what size ?
    cheers
    vx custom 600RR
    Oct 2010
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Try a heavier front swaybar first. most of your cars weight is at the front. A heavier rear bar will make it handle worse because the back will want to step out if you do any hard cornering.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VT Series 1 V6
    Jan 2008
    if you don't already have one, I'd chuck a strut brace on as well. I put one on and made a big difference to the amount of body roll around corners, and cheap.
    VT S-Pack S2
    Sep 2010
    Deff get a strut brace, huge difference i got one in my vt s-pack along with FE2 bigger sway bar and nolathine bushes
    ashbox's Avatar
    ashbox is online now 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    strut braces, sway bars, springs and shocks
    Chev badges are an instant fail
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Just asking instead of making a thread somewhere else.
    Don't the strut braces require holes to be drilled in VT or is that only for the ones bought from Holden?
    Best RPG ever
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by 2DIE View Post
    You gotta drill holes to fit a strut brace (holden or aftermarket) to a vx, So i would think the vt would be the same.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VT S-Pack S2
    Sep 2010
    WHII Statesman
    Sep 2006
    Geelong, VIC
    VS ute, YZF-R6
    Sep 2005
    Yeah that's true balls do nothing to change body roll or stiffness purely there just to look good...pfffffftttt
    Those strut hats on ebay look too expensive btw.
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by V8VKJoe View Post
    Yeah that's true swaybars do nothing to change body roll or stiffness purely there just to look good...pfffffftttt
    WTF sway bars have everything to do with how much body roll a car has. Did you mean strut brace????
    WHII Statesman
    Sep 2006
    Geelong, VIC
  15. #15
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I swear to god you people you people put lead on your weatbix instead of sugar....
  16. #16
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Well just throwing this in, I installed a Whiteline strut brace in the old VR as the Strut towers where starting to crack. anyway i did a before and after test, and found after installing it the nose just pointed into corners so much better, but then found the ass hanging out much easier lol, they do work, i only installed it to try and stop the flex in the towers to prevent further damage.
  17. #17
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by edals View Post
    Might want to not go around corners at 80kmh then. Or perhaps do something with the rest of your busted suspesion if you're have such a drastic change in handling dynamics after fitting something that aids in chassis flex...
  18. #18
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Funny you automatically assume that all the suspension is busted, had everything replaced 10k ago before the brace bar was fitted, Rear/Front shocks & Springs & all sway bar bushes etc all brand new parts.
    Again, Its a VR, Alot has changed over the years between the cars, and was fitted to prevent further damage to the cracking body filler around the strut towers.
  19. #19
    Commodore M6
    Jul 2010
    East Coast
    strut bars shouldn't do much except increase your rice
    the front end of the VT VX is reasonbly square and true as it is
    sways bars = yes
    strut bars = rice
  20. #20
    Nov 2008
    Smithton, Tasmania.
    If it effected the handling to the point where it easily induced oversteer, Something was seriously wrong. They DO NOT effect it that drastically. No ammount of self delusion will make it any different.
  21. #21
    VS ute, YZF-R6
    Sep 2005
    Quote Originally Posted by SirNemesis View Post
    Swaybars and strut braces are not the same thing. Swaybars will help, but IMO decent springs/shocks should be done before you go overkill on a swaybar. It is all about 'the package'.
    AAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRR I'm a re - tard! I swear I read you typed in swaybar ####### ###### and there's no excuse, nobody even said swaybar till then on this page
    Definately 'the package' has a better overall result and heavy duty swaybars would lessen the body roll of the vehicle, if he's fitted decent springs and shocks.
    So I takeback my comment.
    Soop I did add a sprinkle of lead to my egg's this morning. Tasty sh#t. :P
  22. #22
    VS ute, YZF-R6
    Sep 2005
  23. #23
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by soop View Post
    What ever soop, was my input, do the test your self if you must :P
  24. #24
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Im surprised my screen didnt melt from all the flaming ive read in this thread!.
    @ OP, a simple change of tyre will help to eliminate "body roll" to be as minimal as possible. it will always be there.
    lower the wall of the tyre eg from 65 down to 45 (eg 17" Rims)
    Then compliment it with your struts and springs you say youve updated with and you will be set on your way.
    another suggestion, slow down? lol
  1. vz sv6-cant improve on perfection.
    By big dan in forum VY - VZ - WK - WL - V2
    Last Post: 11-08-2009, 07:42 PM
  2. What should i do to improve my vy
    By nezzy88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-09-2008, 08:07 PM
  3. Would this improve performance at all?
    By Razor- in forum General
    Last Post: 10-08-2008, 02:10 PM
  4. wat can i do to improve my performance in my VT ??
    By 07miana in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2007, 11:52 PM
  5. how to improve the handling of a vh
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-09-2005, 10:37 PM
