Results 1 to 7 of 7
Thread: Help: Error Code 47
    2000 Commodore VT Series II Olympic Edition Wagon
    Apr 2011
    Default Help: Error Code 47
    Hi guys, sorry for posting a 'help' on my first post
    But I'm hoping someone more experienced might be able to shed some light on my problem.
    I did do a search and a google but not much luck narrowing down on '47'.
    2000 VT series II wagon, V6 auto, 200K kms on the clock, just bought it a couple of weeks ago.
    Normally starts first kick even when cold, but intermittently will not start, cranks but won't fire.
    Also once it has cut out on me, sudden loss of ignition, then again wouldn't restart.
    When it doesn't want to start, turning the key off an on a few times and then it starts OK again.
    Otherwise seems to drive fine with no apparent issues.
    Checked the error codes, it's throwing code 47, and going through my trusty Gregory's, I've done the voltage tests on D4 and the voltages are as they should be, which indicates faulty ecu
    We've checked and cleaned the cam/crank/DFI connectors. I've also reset the codes a couple of times and after a reasonable drive it always logs 47. So there is definitely something wrong but ecu seems a bit extreme. Is there anything else I should look for / test before replacing the ecu?
    Thanks
    VT Acclaim Wagon
    Oct 2008
    Something to do with CAS (crank angle sensor, behind the harmonic balancer) or DFI module. Odds are that it is your CAS or wiring
    Code 46 - No Reference Signals While Cranking
    Code 47 - 18x Reference Signal Missing
    There at least 4 codes referring to no crank signal
    VX Executive S2
    May 2006
    Frankston South Vic
    Apr 2011
    Thanks for your responses guys.
    We originally suspected the CAS, but the only error thrown is 47, which for the VT is;
    Crank Angle Reference Signal (No Signal).
    The Gregory's provides several tests to determine the cause, which according to them, will be either faulty ecu or faulty DFI module.
    The first test is to check the voltages going to pin D4 on the ECU from the DFI module. If these voltages are correct then the problem is the ECU, which is what I've tested.
    Thinking about it this morning though, I did this test when it was starting. I probably need to do it when it's not wanting to start.
    Either way Gregory's is suggesting the DFI module not the CAS if this voltage test fails.
    So I'll try and get it to 'not start' again today and test it then. If the voltages are still OK then it looks like I'll be getting a new ECU
    Otherwise I'll swap out the DFI first and hopefully this fixes it. I figure swapping out the CAS will be a pita job...
    vs commodore
    Oct 2009
    Tamworth NSW
    Id be replacing the CAS first,its located behind the harmonic balancer which has to first be removed so you can get to the CAS,you need a harmonic balancer puller tool which are cheaply available from places like supercheap to remove the balancer,the CAS itself is just held on with 2 bolts and is easy to replace once the balancer is off.The reference signal is generated by the CAS in the first place, and code 47 will set if there is no reference signal generated by the CAS,It could also just be an intermittent problem with the CAS seeing the car still runs etc,so thats where Id start,and Id only fit a genuine CAS from holden.I just bought one not long ago for $120,you can get them on ebay for $40 or thereabouts,but they can be faulty from new, and they dont last very long,Ive ran into a few like this now,so they end up costing more in the long run than genuine ones do.
    Apr 2011
    I ended up taking it to Holden today to get an official diagnosis, they confirmed it's the CAS.
    Now I just have to weigh the time and drama of doing it myself without all the right tools or have someone do it for me. I'm not real keen on the starter motor method of removing the bolt, might try the belt method Then need to get a puller from SC. Word is it's hit and miss whether the pulley will come off easy or not? Sometimes they can be seized on? Anyone had a problem getting the pulley off with a 3 arm puller?
    Also do you need to pull the radiator out to do this or just the fans will be enough?
    And I'll def get a genuine one, they're not that expensive, and a new crank seal while I'm at it.
    Apr 2011
    Well I decided to wimp out and get my mechanic to do it. Turns out the pulley came off pretty easy but the bolt was a complete bitch, so I figure that was a couple of hundred dollars well spent
    Turns out it was the crank angle sensor, has been about a week now and no more problems. I went with a genuine cas though, and put in a new crank oil seal for good measure, so I shouldn't need to take this off again for a while
  1. error code 26
    By sharon4bears in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2010, 10:27 AM
  2. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  3. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  4. error code 13
    By MAC-VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2009, 11:26 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
