Results 1 to 5 of 5
Thread: Sound Problem Eurovox Radio
    VT 2000 Commodore Station Wagon
    Apr 2011
    Moonee Ponds
    Question Sound Problem Eurovox Radio
    Hi all,
    I have a problem with my radio that has me perplexed.
    Its the standard eurovox radio/cassette.
    Sometimes when I start the car it works fine. Other times I will start car and there is no sound (all the standard info on it is displayed, just no sound.)
    If it starts fine, and then I drive somewhere and stop and shop. When I get back into the car no sounds come from it.
    Its intermittent. Can work ok one day and not the next.
    Had unit taken out and hooked another unit in and same problem existed.
    If it is not the unit, what else could be causing the problem.
    Checked and replaced fuses
    Any thoughts greatly accepted
    Best regards
    VX acclaim S2
    Oct 2009
    Think.. Not fuses not unit, has to be wiring... Check the plug to See if all pins are totally pushed in, check ground, or even run new power n ground wires direct from the battery
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Wouldn't be power or ground otherwise the unit would completely shut off and you'd have no display. Does the problem exist when you listen to a tape or plug an iPod into the "CD" input jack?
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    check to see that the wiring to all speakers is good. many head units will shut down if a speaker is shorting out, to prevent themselves from blowing up,. Had exact same issue on the VB.
    Apr 2011
    Moonee Ponds
    Default Fixed
    Quote Originally Posted by c2105026 View Post
    That was the problem.
    Checked out all the speaker wiring and traced the problem back to where the installer spliced the hands free mobile installation into the speaker wiring. (this was done about 8 years ago and since then the hands free unit had been removed from vehicle)
    As you mentioned, the shoddy splice area was shorting out and shutting the head unit down.
    Ran a new wire and it now works a gem.
    Thanks to all for your help in identifying the problem area
  1. Eurovox premium sound VS code problem
    By coolngroovy in forum Car Audio
    Last Post: 09-07-2010, 02:22 AM
  2. Eurovox Radio - Reset PIN
    By Tekit in forum Car Audio
    Last Post: 26-05-2010, 09:59 PM
  3. VP Eurovox radio, NEED HELP!
    By FQN714 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2009, 09:06 AM
  4. VP Eurovox radio, NEED HELP!
    By FQN714 in forum Car Audio
    Last Post: 09-12-2009, 01:56 AM
  5. VP Eurovox radio
    By VPFreak in forum Car Audio
    Last Post: 06-05-2005, 11:35 PM
