Results 1 to 14 of 14
Thread: Engine oil!!!
    vx lumina
    Sep 2010
    adelaide
    Default Engine oil!!!
    Hi People,
    i have a vx lumina 3.8 l was wondering if any could recomend a really good engine oil and the viscosity i do about 28,000 kms a year to and from work and i take her on drives a couple of times a month. thanks in advance
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    20W/50 I use this and its fine,if your car has done alot of kms then use the SUPER 20W/50
    97VT SS super6,daily 05 holden barina(opel)!!
    May 2009
    I used to use penrite HPR 10W/50 think it was but now car has over 200k so use penrite 20W/50 and runs like a dream!!
    Also check my ride,sitting on HSV R8 19's
    " And on the Seventh day ,GOD created Commodores!!!! "
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, 20W50 is the oil of choice for the ecotec.
    Visit my Facebook page
    vx custom 600RR
    Oct 2010
    i know this has/is done time and time again but....
    since having my car converted to LPG i've noticed it uses more oil, first oil change when i bought the car which had fresh oil in it was .5 of a litre down on the first change. i don't know what oil was used, i've used castrol magnetec 10w40.
    since having the car converted to LPG which burns hotter and it's now using around 2 litres every 5 to 6 thousand K's
    so tomorrow i'm changing to penrite semi synth 15w60 hope fully it will use less oil
    BTW the runs like new with no issues
    i guess as the engine ages gets modified the oil needs change
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I use this. Been in my motor for 2 years.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    hey mate your best bet is to check your service records and just keep using whatever its been serviced with before
    If it isnt tuckin, it must be suckin
    vx custom 600RR
    Oct 2010
    so i changed the oil today went from castrol 10w40 which i was very happy with, to penrite 15w60
    all i can say WOW, who would of thought oil could make such a difference, the engine is super quite and feels better than ever, not a single tick from a cold start
    i guess as someone mentioned above the older the engine the thicker the oil should stay at when at temp
    my engine is at 210,000 k
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by oska View Post
    Is that the penrite semi synthetic HPR15? I use that in my VS ecotec and Ive found its excellent oil...fairly cheap too.
    ss Thunder crewman
    Aug 2009
    yeah i use the penrite HPR 15 in my missus vx wagon & when i found out what oil holden used in my ss Thunder 6.0ltr think it was that valvoline syn power changed that to full synthetic penrite & it was the quietest 6.0ltr while running & when i sold that & got a seven seater Gu patrol due to to many kids lol
    i even changed that to Hpr 15 i,ve used penrite oil for all the cars i have had since i was 18 & will never change even use penrite out board oil & 2 stroke oil for my boat
    vx custom 600RR
    Oct 2010
    yeah mate that's the one
    i really was surprised that it made such a noticeable difference
    May 2009
    Quote Originally Posted by Brett_jjj View Post
    I have to agree that penrite HPR stuff is awesome +1...all i ever use is penrite
    vx custom 600RR
    Oct 2010
    Default update
    all i can say is awesome
    the engine is so quite and so smooth i can't believe it
    oil WTF ? it makes a difference ?
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    I Just bought Penrite 15-60 Semi today. As listed
    The Penrite Semi-Synthetic HPR 15W/60 packaging shows this oil meets the latest API SL/CF specification as required by Porsche & Mercedes Benz.
    Must be good shit. Going to put it in the VY tomorrow cause 10-40 is too thin and burns, both the VY & VX do it. and cause it gets to 45+ here on hot days and in traffic even more, should be suited very well.
    15-60 is recommended for 20-50 / 15-40 & 15-50 range.
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
