Results 1 to 14 of 14
Thread: VX Suspension Clunk
    VX Executive S2
    Apr 2011
    Mandurah
    Default VX Suspension Clunk
    Hey all,
    Had my vx exec for almost a year now been pretty good until lately. Just yesterday i started hearing a clunk sound coming from what seems like the front suspension, tried jacking up the right side to have a better look and the car raises but the wheel stays firmly on the ground everything seems fine and tight except the top of this feels sort of loose
    Im fairly sure its the shocks gone, any ideas fellas? And if the shocks do need replacing im going to be lowering my car so would it be a good idea to lower it while they replace the problem?
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Do you meant he top of the skinny little rod feels loose? Thats the sway bar link which is the most common cause of knocks and clunks from the front suspension and costs around $50 to replace with brand new Nolethane parts. Yours look like OEM sway bar links...
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    VT
    Feb 2010
    I put new Nolethane sway bar linkage brushes in and new nolethane strut tops and shocks in and the clunk is still there.
    This is where I think the chunk is coming from
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    To test the shocks, have the car on the ground and press down on the corner of the car to try bounce it up and down. The car should bounce a few times and then settle. If it's stiff, then that''s a sure sign the shock's seized (duh )
    Check the top bushing on the swaybar droplink, if it's split, then it needs replacing.
    Also, it could be a strut top bearing that's failed. But, money's on the droplink at the moment.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VX Executive S2
    Apr 2011
    Mandurah
    Hey yeah car bounces a few times and settles fine
    the sway bar is stock from my knowledge im leaning towards the sway bar link at the moment how do i know if it is the cause?
    i dont know how to judge if its split or not but the nut is semi loose and all the washes are free moving
    VX Executive S2
    Apr 2011
    Mandurah
    Think i just diagnosed the problem, right hand side link is missing one of the rubber pieces and all the washes and bar is quick loose.
    Does this sound right?
    VX Executive S2
    Apr 2011
    Mandurah
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    VX Executive S2
    Apr 2011
    Mandurah
    Do you know if its alright to drive as is until next week when i can book it in to get fixed? And im probably gonna get a heavy duty polyurethane link kit installed, anyone know the best place to go for it? Maybe pedders?
    Mick1988's Avatar
    Apr 2008
    Go to Repco and then fit it yourself. Its a 1 hour job and that's including the time it takes to drink beers during the job.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Quote Originally Posted by Stanko View Post
    Yeah it will be fine to drive mate, i drove my VX like that for a few months till i found out what was doing it. I Just replaced the Rubbers For like $4, but you can get complete links for about $40.
    VT Acclaim Wagon
    Oct 2008
    Dec 2009
    That kit on e-bay has rubber bushes. I got 4 new rubber bushes from Holden, they cost me about $12. When fitting them you need to have the weight of the car on the wheels so the car needs to be on ramps or similar and just do the nut up until the ruber stops turning, don't squash them.
    VX Executive S2
    Apr 2011
    Mandurah
    Thanks for the help fellas, just bought a heavy duty polyurethane kit from pedders for $60 might have a crack at it tomorrow
  1. front 'suspension' clunk
    By P930 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-01-2010, 11:26 PM
  2. clunk noise from front suspension?
    By frustrated in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2009, 10:03 PM
  3. Rear suspension noise(clunk)
    By jonbot in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-06-2008, 11:16 PM
  4. clunk at front left..all suspension new
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2008, 12:31 PM
  5. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
