Hi all, does anyone have a picture/diagram etc of which wires to join to bypass the BCM to make the drivers window go down. I am stumped as to which ones to join up.
I know its green/black to green/orange, just not sure where to cut them.
Any help would be much appreciated.
Thanks
hey curtis well you know the colours thats right , they are located on bcm connector 1 ,what i did is i untapped the wiring that goes to bcm connector then i cut the green/black and the green/orange and left a good inch of wiring left to the bcm connector incase i wanted to rectify the bypass incase of a bcm change. So cut those 2 wires about one inch away from the bcm connector and join those 2 wires together and your done . The only thing if you dont know is that you wont have the auto down function which is no big deal as hat shit me anyway but once those 2 wires are joined your cruising. The wire locations on bcm connector 1 are green/orange in position 2 and green/black are in position 14 but if you want the diag send me your email addy.
