Hey just wanted to know the best and easiest way to change fuel pump in vt sedan! The cars cranking but when I turn the ignition on you can't hear the pump working. If it's not fuel what else could it be!
Check the pump is getting power, first up remove the relay and bridge the contacts if the wiring is OK and there is power the pump should run all the tme.
If the pump needs to be replaced you have to remove the fuel tank as the pump and sender unit comes out from the top of the fuel tank. Just get a DELPHI replacement (pump and sender) they are on e-bay and are the same as OEM.
