Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Coast_Calais
Thread: coolant change
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    Default coolant change
    hello all,
    I have a 2001 vx with very low mileage, and from what I can gather the coolant has never been changed.
    I attempted doing a 40,000km service today but the coolant change stopped me. Was able to drain the radiator ok but pulling the knock sensors out of the engine block is impossible. There is simply no room to work!! Needless to say in attempting to unplug the wiring, due to the lack of space, I broke the wiring to the passenger side knock sensor. As a result I have given up on this 40,000km service; dealer is doing it tomorrow. I was able to do air filter, spark plugs and oil/filter, i suppose thats a start....
    How vital is it to drain the engine coolant in the block? I figured that if I drain and refill the radiator with every oil change then the basic result will be the same.
    WL Caprice & VQ Stato
    Feb 2011
    Seaford
    never worried about the knock sensor lol on my mums old VX we changed the coolant every 40-60,000kms just flushed the radiator and engine out with a hose both ways until the water came out clears then filled it all back up again
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    For a coolant flush, I normally just take a few hoses (radiator and some heater hoses) off, and progressively flush with a hose. Do this a few different ways until the water runs clear from all areas (have your heater open to flush the heat exchange) and she'll be good to go.
    Fill with fresh coolant, bleed, top up and beers...
    Feb 2011
    Seaford
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    im more impressed with the fact its only done 40,000kms...
    Going where no late model stato/caprice has gone before.... GAME ON!!
    Feb 2011
    Seaford
    yeah me too, read that after my first post, then I got reminded about beer :P
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    You don’t need to drain the coolant at the block, I used the method below with quite a bit of success; sure it might not be the "right" way, but it works for me.
    *Start car and let engine run for 10 minutes (refer below for the reason for this).
    *Pull of top radiator hose, stuff a hose into the radiator turn on the hose.
    *Start the car and leave run for "x" amount of time, what this will do is push clean water though the radiator (heating it), though the block, and out the thermostat.
    If you leave the hose run, and the engine cycle it's coolant a few times (i.e. thermostat open / close) eventually there will be clean water coming out of the block.
    *Turn off the car, stop the hose and do up the top radiator hose; now undo the bottom radiator hose and let it drain the water out of the radiator.
    *Do up the hose, and fill the radiator with coolant.
    Now you have clean coolant, and water in your radiator... I have done this a number of times on a Holden V8, it's worked a treat and my coolant is always that nice green colour.
    A word of warning though, make sure you heat the engine and radiator first - never put cold water straight into the block as it can cause cracking (this is why I run it though the radiator first). Also be careful of the water coming out the top hose, as even though it is fresh water it will still is circa 100⁰C after cycling though the engine block.
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    varies
    Jul 2008
    gone
    Quote Originally Posted by D-Renzow View Post
    how could I forget the beers!!
    That's blasphemy !!!
    I believe all workshop manuals should have an intro for each service job stipulating required beers for completion. Just for accuracy/comparo
    Feb 2011
    Seaford
    Quote Originally Posted by Coast_Calais View Post
    Great thinker here guys! lol
    Aug 2009
    Orange NSW
    The Haynes manual I had for the Peugeot 306 I had had a spanner rating for each activity. 1 spanner meant your mum could do it, 5 spanners meant leaving to a proper mechanic. I guess you could use that as a guide.....
    varies
    Jul 2008
    gone
    Quote Originally Posted by c2105026 View Post
    1 spanner = 6 pack
    5 spanners = carton + mates + BBQ
    Feb 2011
    Seaford
    1 spanner = 6 pack
    VP Exec
    Jun 2005
    I don't think that anyone removes the knock sensors. Well, very few people.
    If you flush it through with the thermostat removed (heater on) till water runs out clear you will be left with some water trapped in the block with the sensors in place. Refill with concentrated coolant sufficient to make up to the desired overall concentration calculated using the specs. for the car then top up with water.
  1. Coolant change
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-08-2010, 07:22 PM
  2. Coolant change or not in a VC 202...
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-03-2010, 02:17 PM
  3. Coolant change SV6
    By diysv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-01-2010, 04:02 PM
  4. How Do i Change The Coolant
    By MY-42-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-10-2009, 06:18 PM
  5. Coolant Change
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2005, 09:39 AM
