Results 1 to 7 of 7
Thread: vt 3.8 droning vibration after replacing engine mounts
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    Unhappy vt 3.8 droning vibration after replacing engine mounts
    are aftermarket (repco) solid rubber engine mounts less effective at reducing vibration than factory hydraulic mounts
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Yep sure are, they use the hydraulic ones from factory so you should stick to them.
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    yes,i didnt do them myself,they were done by my local mechanic who i've been using for 12yrs.in the past he's been brilliant but i think that this time he' stuffed up.
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    thanks mate i guess i just wanted to hear someone else say what i have suspected.my car's done over 350,000 k's and i've spent plenty on it over the years to keep it running great but i think my mechanic must be going through some sort of mid life crisis because cos the last couple of jobs he's done have been not quite up to what i've expected eg my transmission was running pretty crappy so he told me i needed a recon one but thanks to this site i tried other things and eventually simply replaced plugs,leads and coils with genuine parts and the problem was solved.that was 50,00 ks ago
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    VT's don't use hydraulic mounts, they're solid rubber. As suggested, whats the condition of your trans mount? Your old engine mounts had likely sagged quite a bit so check you exhaust is not rubbing anywhere also.
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    problem solved.replaced the solid rubber mounts with genuine hydraulic mounts -- no droning--thanks for comments
  1. Replacing Engine Mounts (anyone in Adelaide?)
    By mayes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 02:19 PM
  2. Replacing front engine mounts on 6cylinder VT
    By javjup in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2009, 08:30 PM
  3. Replacing Engine Mounts
    By truni in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2008, 08:47 AM
  4. Spacers between center bearing mounts to reduce takeoff vibration
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-03-2007, 12:13 AM
  5. replacing engine mounts on a VT
    By Stue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2006, 09:44 PM
