Originally Posted by
DanLucas
real easy to get them off mate.
first take your door trim off, then you will see this ugly carpet looking crap, peel it back (only glue holds it on). once youve done that, at the top of the old trim you will see about 5-6 bolts holding the top part in, you can undo them with a small shifter, then at the bottom you will see 3 black clips, just slide them up and they come off easy, and there in the one screw down the bottom.
replacing the inserts in a vt is so easy mate, once u have the door trim off you will be able to see what you need to do. no parts need to be broken and there are no gay pop screw crap like the speaker grill very straight forward.
