Does anyone know where I can get some brackets to space a VT commodore's calipers to make them fit over 330mm rotors?
There is a guy on eBay that sells them, so I know that someone makes them.
I just wanted to know if there's anyone else out there that has done the upgrade and where you got them from and how much they cost?
Glenn
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
theres a sponsor on here, GSL Rallysport, i know they do VE brake upgrades with the 330mm option so they may be able to help you
Going where no late model stato/caprice has gone before.... GAME ON!!
yes they are
I've double checked GSL's thread and they only fit 322mm rotors from what I can see.
Whats the big advantage of the VE calipers over the VT ones?
Because there is two options for the VE calipers to fit onto 296mm/322mm rotors does that mean they're spaced to fit onto the 322mm rotors or are they different calipers all together?
They come with spacer brackets to suit the different size rotors. The calipers have smaller diameter pistons so this kit doesn't require any master cylinder or booster change.
I do the kits too for $795.
