Results 1 to 4 of 4
Thread: VT Wagon LS! Rad Fans suck or Blow?
    VX Wagon
    Sep 2010
    Default VT Wagon LS! Rad Fans suck or Blow?
    Hi All,
    Replaced the radiator in the VT LS1 on the weekend, and standing at the front of the car this arvo noticed the fans are blowing and can feel hot air on the leg standing next to the grille at the front of the car. Question is should factory fans blow hot air thru the radiator, or suck cool air?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    They suck air in, think about it, trying to blow air out while air is trying to come through the front when your driving along wouldnt be much good.
    VX Wagon
    Sep 2010
    Thats why I asked...after I replaced the radiator and reconnected the fans they now blow air towards the front bar....so not being a professor I have something wrong Cheers
    VT Acclaim Wagon
    Oct 2008
    Are you sure the warm air you are getting is not coming from under the front bar? Between the bar and the ground? While the car is standing still the warm air from the fans can be reflected by the motor etc and be pushed out from under the car toward the front. BTW, it's near impossible for the fans to be connected the wrong way as the connections are designed to go together one way only, so reverse polarity should not be the issue.
  1. Does this suck or what?
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-03-2010, 11:04 PM
  2. I Suck
    By voney in forum The Pub
    Last Post: 27-12-2008, 08:57 PM
  3. This would have to SUCK!!
    By brownie82 in forum The Pub
    Last Post: 27-10-2006, 01:27 PM
  4. commodores suck!
    By ZER0 in forum General
    Last Post: 26-10-2005, 08:06 PM
