Results 1 to 5 of 5
Thread: power steering pump installation
    VT Executive
    Apr 2011
    dromana
    Default power steering pump installation
    hey guys first post,
    just wondering if you could help me out, i need to get a reconditioned powersteering pump installed on my VT. id give it a go myself but im pretty hopeless under the bonnet plus i cant disconnect the battery terminals without a mechanics recepit cos i have an interlocker
    how much should this cost? im already going to get the pump off ebay for $120 odd
    any help would be wicked
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    super cheap have new ones for close to the same spot. about 80 should get it put on. i never disconnected the battery when i did mine. just be careful when you take the hoses off. they are brittle
    i do as the voices tell me
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    COMMODORE V6 VN,P,R VS VT,X VY POWER STEERING PUMP NEW | eBay
    I Just bought this, Brand new pump. Should only cost about a Hour work shop labour if that about $80 prolly. But ill just fit it my self.
    VT Executive
    Apr 2011
    dromana
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Its really easy to change. Back off the 4 10mm bolts holding the pulley on, remove belt, remove pulley, 2 x 13mm mounting bolts, and 1 x (15mm/16mm) threaded high pressure line on rear of pump and its off.
    Power is measured in DECIBEL
  1. Power Steering Pump
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2010, 04:24 PM
  2. Power Steering Pump Removal/Installation VN/VP
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 29-04-2010, 03:35 PM
  3. power steering pump
    By go fast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 02:07 PM
  4. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  5. Power Steering Removal and Installation
    Last Post: 19-04-2006, 10:48 AM
