please help me, i want to put the HSV dash out of my late fathers VU Maloo, into my supercharged V6 VT, (s pack)
can it be done? cant it be done? what do i need wiring wise, whats the deal.. i really need to know if theres any way it can be done, if the whole assembly cant go in, is there any way i can just use the face? i just want to have a little piece of my dad in my car..any info greatly appreciated. thanx
By dash do you mean the instrument cluster? If so, then yes you can put it in your car but you will need to get it calibrated to suit your car. This will require a Tech 2, so you will probably need to go to a Holden dealer.
MY RIDE
awesome, have you done this personally? (and yes the cluster) i was told there would be issues coz its going from an 8 to 6, and the speedo goes up to 250, not 220.. can this all be fixed by callibrating? or do i need to do anything else? and what about the extra sensors and lights in the HSV dash, can it be set up for it to all work? or will i loose some of it?? thanx for your reply.![]()
The cluster stores info on the drive train - gearbox, diff ratio, rim/tyre combo, air bags, climate control/ A/C, fuel tank sender and engine along with kms.
All this needs to be calibrated to your car. try Pheddy on this forum - he may be able to help (it may take a little time tho)
and 3 Dangerous non ABS VN's
changing it over will require a tech2 to recalibrate it... i did mine the opp way round, mine came out of a xu6 and got it calibrated to suit the ls1
click on this link mate http://www.excelerate.com.au/downloa...nt_program.pdf and print it out, i did this so the guy that calibrated it knew exactly what needed to be done...
hope this helps mate
Larry
thanx a heaps guys.. im also selling a VU SS ute, body is a write off, engine and box ok, not on rev's, so possible repair,$3500. also an ex HSV stunt ute, body in really good nic, asking around 5 g, inbox me for details and ill send a my number if your interested or know anyone interested , cheers
The dash can be programmed to work no problem, but if its a 250km cluster, anything after 100kms will be wrong (showing faster than you are actually going), but 0 - 100 will be fine
awesome. thanx guys!!!
