Results 1 to 15 of 15
Thread: VX Front end Bush replacement suggestions ?
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Question VX Front end Bush replacement suggestions ?
    For the last 2-3 weeks i can hear a vibration noise coming from the front, the noise is like when you drive over the white bumpy line on the side of the high way. Just wondering if it would be a worn bush and if so which one should i be looking at???
    I already no i have to replace the radius bushes, ive got a set of whiteline just have to put them in.
    any suggetions on which ones i should replace aswell?????
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VX Calais LS1, VS Calais L36
    Mar 2010
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    As suggested get the wheels re-balanced but also have a look at the Top Strut mounts, the original Holden ones tend do shite themselves quite often.
    Might also be good good idea to take it to a suspension shop for a quick look over by a professional...
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Darcon666 View Post
    done that with pedders, they had a $14 safty check and gave me a $500 quote on so called spilt and thorn bushes. some how i dont believe i have that many problems under the car.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Mar 2010
    If it's vibrating the whole time I'd seriously doubt it's bushes. My money is still on tyre balance.
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by MR_VX View Post
    There's your problem right there Pedders(RipoffFcukingA55holePricks)...
    Not the $14 saftey check... Just surprised the carnts didn't say the car was unsafe and so would not give you the car back.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by goose202 View Post
    its not the whole time. only when im driving around slight corners and that.
    yeah ive heard a few times that you never end up with just a $14 bill from them the pricks.
    VXII Berlina 3.8L
    Oct 2005
    That's strange, I took my car to pedders for the $14 check and they said the front end was fine with the exception of the sway bar bushes. I took it in because the steering wheel on my car vibrates above 100km/h. I have had the wheels balanced but no improvement (tyres have only done 25,000kms). Looking at replacing the engine mounts as they are stuffed. The sump sits about 10mm below the cross-member.
    Have you had you engine mounts checked?
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Buy Nolethane bushings and fit them yourself. DIY is your friend.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Swaybar link bushes are common and will make a rattle noise as the rubber donuts split and fall out resulting in the washers vibrating against metal.
    Silver Certified.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Sam_100 View Post
    yes pedders said they where fine, but to me they looked fingered. lol
    Quote Originally Posted by Mick1988 View Post
    I have a set of whiteline radius rod bushes to swap over this holidays.
    Quote Originally Posted by RiCeY View Post
    I should do the saybar bushes, are they a hard job?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    IMO if the bushes havn't been done before then do the lot if you plan on keeping your car.
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Try the link below.
    If you replacing the radius rod bushes you may aswell compliment them with replacing the other bushes aswell . you wont regret it. I didnt
    I didnt find any difference between the VS and VT front end. Ive worked on both.
    The link has pics in there somewhere aswell
    or better yet PM me if you need any more info.
    I did 2 cars in the driveway, saved bucket loads of cash on labor
    VS Suspension Advice
  15. #15
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    DIY is your friend.
    just remember to not over tighten the bushings as they will die pretty quickly.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
  1. VS Link pin and bush replacement
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2007, 01:46 PM
  2. How do i replace front camber bush
    By hsv14u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2006, 03:46 PM
  3. Need suggestions on brake rotor replacement
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-05-2006, 12:27 AM
  4. z-bar removal / bush replacement
    By BOX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 09:43 AM
