Results 1 to 22 of 22
Like Tree2Likes
  • 1 Post By VK SL 3800
Thread: is this a gud thing or a bad thing?
    VT II Executive Wagan
    Mar 2011
    Default is this a gud thing or a bad thing?
    ok i got a vtII wagon not long ago n now when im on the high way my eng temp will stay at the low low end or even at the bottom it will not rise untill i get off the highway or till i stop my car, is this a gud thing to have in ur car or not is there a problem?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Mar 2011
    Nov 2008
    Smithton, Tasmania.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Sounds like the thermostat is stuck open, but most engines eventually warm up even with it stuck, if you stop and wait for the temp to rise then start driving again will it stay in the normal range or drop back down again?
    Mar 2011
    if i want to try figer out what could be the problem where can i start looking? thermostat? radtaor?
    Mar 2011
    i havnt try that but i will cus im goin down to wollo on the 25th i will tell u how it goes
    from my memory i believe it will stay but im not 100% sure
    Mar 2011
    oh one more thing n it might be stilly to ask y its bad for the engine cus i rally want to keep this car for a long time as this is my 1st car
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    stuck open thermostat. replace it and flush the coolant while you're at it. mine was doing this exact thing when I first got it.
    Mar 2011
    kool sound like a easy fix then i need a flush too so yeah sound like a gud timing but i will need to do it after april tho u think its ok to hang in there for a lil longer?
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by hunterjerry View Post
    Ehh not sure. Running cold would have to be better than running hot... Not sure if it would do any damage. Soop?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Bad for engine as until the engine is at normal operating temp engine wear and tear is at its greatest.
    Mar 2011
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Dont worry too much, its not as if the engine is tearing itself apart.
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    ouch then i gues i need to womr her up 1st then ><
    That's the thing though, it won't warm up because your thermostat is stuck open - thus allowing coolant to flow through the engine ALL the time.
    Normally it opens and closes when the engine reaches a certain temp.
  16. #16
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
  17. #17
    Mar 2011
    kool it warm up n in okish traffic it hang around 79-85 n in bad traffic it hang around 80-107 so far
    whats the best running temp on my VTII V6??
  18. #18
    VT SS S2 A4
    Aug 2005
  19. #19
    Mar 2011
    thx guys i will replace the thermostat asap by any chance there is a how to for this?
    nvm i will have a look 1st
  20. #20
    vx/ 2001
    Oct 2010
    iraq
    Its kind of NO thermostat at all, if you are sure nobody played with last repair then you have problem with it need to change, Most of them stuck closed not open, If so then the thermostat ran normally in summer , but in winter is so bad since it would wasting more gas with engine effected either
  21. #21
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    or the plastic seal around outside is perished a little bit, same prob with mine running cold. if your car hasnt had a flush for a while be ready for other parts in your cooling system to leak as flushing will remove small bits of build up that will dislodge and then the water pump, radiator will start to leak! completely your choice though, you may not have any problems at all.
  22. #22
    Mar 2011
    mahaha it turn out the last owner didnt put a thermostat in it so now we know why lol=D all fix n flush the system thanks to all of you =D n who did the how to on it as well =D
  1. what is this thing??
    By unregistered in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-06-2009, 08:53 PM
  2. What Is This Thing
    By tyrefryer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2008, 11:25 AM
  3. Is there such thing as....
    By Iwannabeahsv in forum Car Audio
    Last Post: 10-02-2007, 08:52 AM
  4. Replies: 14
    Last Post: 08-12-2006, 03:12 AM
  5. Next Best Thing
    By Shiney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2005, 07:43 AM
