Results 1 to 5 of 5
Thread: Gearbox troubles...
    VX Lumina
    Nov 2010
    melbs
    Default Gearbox troubles...
    Recently ive noticed an issue with my gearbox, when it is changing from second to third gear it revs and then goes into third. So it stops halfway between 2nd and 3rd revs and then goes into gear... its almost as if somthing it sticking.
    I plugged a computer into the cars computer to see if it threw up any error codes and it didnt.
    I then serviced the gear box and its still doing it.
    The car has done 130,000 kms so i doubt the gearbox is on its last legs........
    Has anyone else had these troubles or does anyone know how to fix it ??
    -Cheers
    CSP
    CSP is offline Banned
    my car
    Sep 2007
    VX Lumina
    Nov 2010
    melbs
    vs commodore
    Oct 2009
    Tamworth NSW
    It might be a sticking shift solenoid,(far left of pic),you can take it to an auto trans specialist and see what they reckon.If you service your own transmission filter and fluid,then its fairly easy to replace the shift solenoids..You just gotta remove the trans pan to access the solenoids.
    VX Lumina
    Nov 2010
    melbs
    ahh k that sounds very likely, if there not too expensive ill give it a shot, thanks
  1. VS A4 Gearbox Leaking round the dipstick where is joins gearbox.
    By scogie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2010, 11:23 PM
  2. Troubles with my VK
    By Dazza_Bo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2010, 04:02 PM
  3. key troubles
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2008, 12:45 PM
  4. Gearbox troubles
    By Moleman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2007, 11:25 PM
  5. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
