Results 1 to 6 of 6
Thread: Where is the Tacho Signal Wire
    1992 VP Holden Berlina V6
    Nov 2010
    Rockhampton
    Default Where is the Tacho Signal Wire
    hi, I need help with a 2000 vt v6. I installed a tacho in my car and have power and earth for the lighting on the tacho but where is the signal wire?
    There is a connection above the bell housing that doesn't go anywhere and I have been told that is the signal wire.
    If not where can I run the signal wire from? I have pulled the cluster out and probed wires as per instructions from a auto eleccy and found nothing. then told that his instructions are only for a vt v8.
    please help.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If I recall correctly there should be a single wire with a connector taped to the main loom that runs along the firewall on the passenger side. It might take a bit of looking.
    MY RIDE
    Nov 2010
    Rockhampton
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by bobby_wayne View Post
    yeah that's for the early model buicks, vn-vr
    I had it on my VT. Although the picture below is for a supercharged model it should be there in other models as well.
    Attached Thumbnails Attached Thumbnails Where is the Tacho Signal Wire-tacho-connector.jpg
    MY RIDE
    Nov 2010
    Rockhampton
    car
    Jul 2006
    greensy, melb
    didnt your car come with a tacho in the dash?...
    "A life lived in fear is a life half lived"
  1. RPM signal wire
    By VScommodoreute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2011, 08:22 PM
  2. amp signal wire ???
    By lodgie in forum Car Audio
    Last Post: 28-02-2010, 04:27 PM
  3. tacho question (signal wire???)
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2008, 11:00 PM
  4. no signal for tacho
    By tweakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2007, 03:09 AM
  5. MAP signal wire
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 04:19 PM
