Results 1 to 3 of 3
Thread: Any photos on replacing heater globes
    kazalex's Avatar
    kazalex is offline karen
    red vx series 2 commodore
    Oct 2008
    adelaide
    Default Any photos on replacing heater globes
    has anyone got photos on how to take apart the heater switches to replace the globes in a vx,thanks
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Theres plenty of info and how to's 2 take appart ur dash 2 get 2 ur heater control unit so have a search.
    then 4 the unit itself its pretty straight forward. All u gotta do is pop off the dial buttons with some sort of flat non sharp blade or screw driver (i find a butter knife the best) Once there off take off the 3 screw mounting the unit in place and only disconnect the wiring harness (small black loom) as u dont need 2 remove completly yet 2 determain which of the 3 units u have. unclip the top and bottom clips from the units surround and u will b left with the dial surround, white inner housing and a PCB board, If u have a large PCB the same size as the unit (2 types), then u just need 2 get some torx screw drivers and take out the 3 screws holding int place and u'll see the globes and can pretty much work it out form there.
    If u manage 2 have the 3rd type that has no inner PCB u'll need 2 remove the entire unit as this unit uses the back housing 2 run its own PCB tracks 2 the globes so u'll need 2 replace them from behind the unit. U may need 2 remove the vacume lines, the heater control rod (count back the number of threads so u remember where it goes back) and 1 more larger loom thats 4 the fan speed controls. once they r free as b4 its pretty self explanitory. 2 replace the A/C and demister buttons there is actually a smaller 50x50 PCB behind the A/C and demister buttons where the globes sit.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    kazalex's Avatar
    Oct 2008
    adelaide
    thanks a lot
  1. Replacing Fog Light Globes
    By SV666 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-04-2012, 07:47 AM
  2. How to - Heater Core Removal and Hoses Photos Thread
    By smokin_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2011, 11:57 PM
  3. replacing low beam globes
    By guyman in forum Electrical Wiring / Questions
    Last Post: 19-07-2009, 05:30 PM
  4. question on vt heater control globes!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2009, 12:12 PM
  5. replacing globes
    By higgmont in forum General Discussion
    Last Post: 16-05-2009, 11:59 AM
