Results 1 to 20 of 20
Like Tree4Likes
  • 1 Post By darcycammo
  • 2 Post By ])R@G()N
  • 1 Post By HoZy
Thread: Alternative way to pop the bonnet?
    VT-S
    Apr 2011
    Morwell
    Default Alternative way to pop the bonnet?
    Hello there people.
    My friend has an issue which has us both scratching our heads..
    He has a VT Clubsport 2001 and the battery went flat.
    He took the battery out of the car to hook it up to a charger (didn't have an extension lead i'm guessing)
    Then stupidly locked the car up and closed the bonnet.
    Now he can't get into the car at all.
    There is only one manual lock on the car, the drivers side and it is apparently broken, and with no battery in the car the central locking wont work.
    Since he cant get into the car he can't pull the bonnet release.
    Any ideas?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The drivers door lock is the only way to open it with the key. Does he think it is broken because it won't turn? It takes a bit of effort to turn the lock, you think you are going to break it, then it turns and unlocks the door.
    I didn't think the door lock could be pushed down with the door open.
    Visit my Facebook page
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    VT-S
    Apr 2011
    Morwell
    Quote Originally Posted by knight wombat View Post
    long screw driver and undo the bonnet spring from under the the car
    how does that work exactly?
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    get the battery and a pair of jumper cables get the Positive(red) cable get under the car and put it on the end of the starter motor where the other Positive cable is then get the negative(black/blue) cable and put it anywhere on the motor then hook them up to the battery then he should be able to open the door's
    VS Stato l67
    Mar 2009
    Melb
    VT-S
    Apr 2011
    Morwell
    Hmm nice idea but 2 problems, how do we know which is the positive on the altenator, and most importantly the front bumper/body kit thing goes completely under the engine and blocks access.
    Jan 2010
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Daliex View Post
    You don't need to, it's the starter motor that you need the positive terminal for, and it will be the red cable.
    VT
    Feb 2010
    open the boot and go though middle seat,, Or smash the window with the battery
    Seanyy's Avatar
    Seanyy is offline "HULK"
    VX II Acclaim
    Jan 2011
    Melbourne, VIC
    He cant open the boot, he has no power.
    The battery-window option though, there's an idea...
    Try to use a jack to raise the front of the car up, enough to get to the bonnet release.
    Quote Originally Posted by TrikkBen View Post
    Get a a few pieces of pvc pipe and make your own extractors... That what I did, it came up great and I gained like 40kw from it.
    Quote Originally Posted by f1tzy View Post
    lol umm how do u accidentally sell a car
    Check out my VX II here.
    Comments/compliments/logical abuse welcome .
    Vt Clubsport
    May 2009
    easy,get a long flat head screw driver go underneath the bonnet, put the screwdriver into the bottom of the bonnet hatch, twist it till it realeases the bonnet and then you can open it, this exact same thing happend to my vr. goodluck mate p.s you may need to take off the thermo fans, this can be done from underneath
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    Quote Originally Posted by Seanyy View Post
    would've thought being a vt he'd still have a key hole on the boot
    Chev badges are an instant fail
    VT Commodore
    Jan 2008
    Mildura
    VT
    Feb 2010
    You use hand power to turn the key in the boot lock
  16. #16
    VX series I I ss
    May 2011
    brisbane
    Open the boot manually with the key and go through the center seat .
    If you don`t want to break it , then don`t bring it out to play with it !
  17. #17
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    You are ####ing kidding me right...
    So both the boot lock & driver door lock don't work? You want to get the bonnet open tho...
    So you are trying to steal this car right??
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  19. #19
    Vs excuetive
    Jan 2011
    What if you do that but it wont undo?
  20. #20
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    even with a dead battery, with a VT you can still open the boot, climb your ass through, and pull the lever, you dont need power for either.
    still the angle grinder idea to the bonnet sounds like a solid plan of attack.
  1. Alternative to stethoscope?
    By minux in forum General
    Last Post: 21-07-2009, 08:44 PM
  2. SS Inductions VS. DIY Alternative
    By jamo25 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-02-2007, 12:27 PM
  3. Alternative Alternators...
    By VT-Telly in forum Electrical Wiring / Questions
    Last Post: 12-11-2006, 12:29 AM
  4. Alternative Alternator?
    By mouce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2006, 09:49 AM
  5. alternative fuels
    By HDT_aero in forum General
    Last Post: 11-05-2005, 11:54 PM
