Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By Not_An_Abba_Fan
Thread: exhaust mount bolts tightening sequence?
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    Default exhaust mount bolts tightening sequence?
    does anyone know the correct sequence for tightening bolts on exhaust system?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It's not necessary to tighten them in any particular order.
    Visit my Facebook page
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Installation
    Loosely install exhaust system as follows;
    1. Attach front pipe and catalytic converter assembly, loosely to the exhaust manifolds (1).
    2. Fit bumper rubber to the front pipes and the transmission extension housing hanger (2).
    3. Hook intermediate assembly to suspension with two bumper rubbers. Fit two retaining clips to the suspension
    bracket ends (3).
    4. Fit sealing ring to the rear of the catalytic converter (4).
    5. Attach the intermediate exhaust pipe to the catalytic converter using the two stepped bolts and conical springs
    (4).
    6. Install the intermediate muffler assembly to the rear muffler assembly and loosely install U-bolt clamp (5).
    7. Attach the rear muffler assembly to the body mount hangers with two bumper rubbers (6) and retaining clips.
    Tightening Sequence
    1. Tighten the two stepped bolts at the rear of the catalytic converter, checking that the sealing ring is installed
    (4).
    2. Evenly tighten the U-bolt clamp nuts at the intermediate to rear muffler slip joint (5).
    3. Tighten each flange nut evenly, so that a similar amount of thread is showing on each (1).
    4. Ensure that all bumper rubbers are under load (2, 3 and 6). If this is not achieved, loosen exhaust joints in the
    reverse order to the above. Load the hangers and re-tighten in the sequence described, from steps 1 to 3.
    NOTE:
    The exhaust system should be self-aligning and not require further adjustment, provided step 4 is achieved.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does that manual tell you how to take a piss too?
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    you are a gem. worked perfectly with reduced unpleasant strained growl from the exhaust.everyone who replaces any part of their system should read this and follow your instructions to a tee,thanks heaps
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    BAHAHAHA.
    It might fall off an punch through the floor otherwise, which will result in a floor pan critical warning light on the dash.
    Quote Originally Posted by som View Post
    Wut?
    Doing up the exhaust bolts relieves constipation, who'd have though.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Fitting up the exhaust and letting it hang off the rubbers in it's natural position before tightening anything up is just common sense, didn't think people needed instructions on how to do it.
  1. tightening sequence on vr
    By brian101 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2010, 02:11 PM
  2. V6 3.8 head bolts sequence
    By AlpineRaven in forum General
    Last Post: 14-07-2009, 08:42 PM
  3. engine mount bolts
    By stocky in forum V8 Development and Modification
    Last Post: 19-11-2008, 11:43 AM
  4. head gasket tightening sequence
    By azz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2008, 04:54 PM
  5. tightening water pump pulley bolts - how!?!!?!
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 10:30 AM
