Results 1 to 5 of 5
Thread: Replacing Fuel Pump in VX Station Wagon
    VX Wagon Acclaim
    Apr 2011
    Whyalla
    Default Replacing Fuel Pump in VX Station Wagon
    Ok let me stat by saying I have read many posts on fuel pump replacement and also read the gregories manuel, but im having problems.
    does anyone have a detailed step by step guide with photos for removal and replacing a fuel pump in a vx wagon
    VX series 2 SS 6 speed,VK Royale 308,VN V6 Ute
    Mar 2009
    Coromandel, NZ
    Its not as bad as it looks.Disconnect battery,disconnect fuel lines and wires going to taank.Remove tank and remove pump.Reassemble.I did one a few months ago at work.Looks far worse than it is
    VT Acclaim Wagon
    Oct 2008
    And if you like reading, here is a repost just for you
    This is a largish post but I see some people asking for this set of directions. I think it works for VX and VY as well.
    Sorry, no photos
    TO REMOVE VT FUEL TANK/PUMP
    1. Depressurise the fuel system.
    2. Ensure that no naked flames or other ignition sources are in the immediate area. Syphon fuel from tank, using commercially available equipment.CAUTION:Never drain or store fuel into an open container, due to the possibility of fire or explosion.
    3. Raise vehicle, preferably on a hoist. ( If you have access to one) Alternatively, jack the diff up and place car on stands.
    4. Remove three stone guard retaining screws then remove the stone guard from under the right hand rear guard
    5. Remove the fuel sender electrical connector from its mounting foot by pulling forward to dislodge the assembled connector forward. Once released, depress the locking tab and separate the connector halves
    6. Place a drain tray under the fuel filter area.
    NOTE:
    Ensure that all dirt and foreign material is removed from any fuel
    connection, prior to removal
    7. Remove the quick connect fittings to the vapour canister, return
    line and fuel filter, using the following method:
    Push inwards to release the seal pressure, depress the side tangs of
    the connector, then pull to disconnect.
    8. Disconnect the vapour canister breather hose at the canister.
    9. If required, remove the fuel filter by removing the fuel feed line
    quick connector, then depressing the two barbs on the mounting
    strap nipple.
    CAUTION:
    Fuel will spill from the disconnected filter.
    9. Disconnect the earth strap from the spade connector,
    under the front right hand strap mounting bolt of the right hand
    tank support strap.
    10. Remove the fuel tank support straps as follows;
    Remove the centre strap by removing the rear retaining nut
    and washer, then unhook the strap from the front support.
    While supporting the fuel tank in the center, remove strap (closest
    to the filler neck), after removing the bolt at the front and unhooking
    the strap from the rear support.
    Finally remove strap after removing the nuts and washers from
    each end of the strap.
    11. Lower the fuel tank from the vehicle, left side first, to release the fuel
    filler neck from the body opening.
    Fuel pump removal is fairly simple from here and installation is just reverse of removal. Helps if you have a mate to assist.
    VX Wagon Acclaim
    Apr 2011
    Whyalla
    my main problem is I cant get my hands in to the area that I think has the electrical conection for the fuel pump and that needs disconnecting before I drop the tanks
    VT Acclaim Wagon
    Oct 2008
    Just get the tank to the point where you can lower it a LITTLE so you can get to the connector.
  1. Replacing fuel pump in a VR
    By deathsminion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:37 PM
  2. vs ute fuel pump replacing
    By racin pigeon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2010, 04:38 PM
  3. need help on replacing fuel pump
    By jaz_777 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-01-2010, 05:25 PM
  4. ok so im replacing my fuel pump on my vs ute!! plz help!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 06:25 PM
  5. replacing the fuel pump
    By dusted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2006, 11:19 AM
