Results 1 to 9 of 9
Thread: Fuel Gauge stuck on full
    VT commodore supercharged v6
    Jan 2011
    victoria
    Default Fuel Gauge stuck on full
    Hey guys
    So the vt was filled to the top on saturday and mums been driving it since Saturday
    And it's still shows full and still shows 460 kms on the computer,
    What should I do ?
    Thanks
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    put the cluster into test mode and it should reset the fuel gauge aswell
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    Jan 2011
    victoria
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    hold up and mode while you turn the key on then press mode to flick through them
    Snerty is offline Snerty
    VK Calais LV2 M21 GU4
    Aug 2008
    20 ks east of the melbourne poo farm
    If that doesn't work, It is possible that the sender has become unplugged or is not getting any power... Unfortunately the tank has to be removed to check the plug on top of the tank. Im not sure if there are any fuses you can check
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    my mates vt has done this ever since the fuel pump was changed, we tried test mode and it didnt work, I think its a faulty sender
    Aug 2008
    The gauge will read full if there is no signal from the sender.. I would say he has bent the float arm sideways and the contact is no longer connecting with the sender windings
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I've done this. Replace the fuel pump with a new unit from holden. Today holden only sells the fuel pump and the sender unit as one unit. If you replace it with a used one you could have the same issue. Mine was replaced at a auto electrician for about 300. It's a hard job at home to do.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    my vy did this.. but my just worked itself out
  1. [VZ] Vy vz v6 v8 hsv vdo full gauge pod & sender kit
    By Archers in forum Holden Commodore How-To's
    Last Post: 24-10-2010, 03:44 PM
  2. VY petrol gauge stuck helpppp !!!!!!!!
    By Joey_21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2009, 10:28 PM
  3. Vz fuel Gauge stuck on FULL
    By gyung in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-08-2009, 07:51 PM
  4. Fuel Gauge always displaying Full.
    By mk_re in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-08-2009, 07:49 PM
  5. Fuel Guage stuck above full.
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 04:59 PM
