Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Car dies first time I start it?
    VT Acclaim V6
    May 2009
    Default Car dies first time I start it?
    Hi, My VT Acclaim has been playing up. Symptoms are that when starting the car, it fires and then dies straight away. If I turn the key and start again the car fires up normally.
    The only way to avoid this is to turn the key to the ignition setting for a few seconds and then start the car, in which case it fires up perfectly.
    Any ideas?
    Jules
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    fuel pump...?
    first crank primes it.. 2nd crank it start.. could be dying?
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    Snerty is offline Snerty
    VK Calais LV2 M21 GU4
    Aug 2008
    20 ks east of the melbourne poo farm
    Defiantly the fuel pump. It will get worse when you have less than a 1/4 tank and you are idling for extended periods. Without much fuel to cover the pump it gets hot and fails with increasing reguarity until at the worst moment and place..you are stuck ..Cheapest option is to buy an after market one from Bursons..Also you must change the filter. this is very important
    VT Acclaim V6
    May 2009
    The filter is due for a change anyway, so I guess I will do both.
    Could this also possibly explain why when giving the car "resonable" acceleration from standstill, (like when you give it a little bit of stick to enter traffic) the car feels like the transmission is not engaged for a moment? It doesn't die, it just takes a millisecond to engage, and then comes on with a thump. Sorry if this sounds vague. There's no error codes BTW.
    Jules
    D3CID3R's Avatar
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    wouldnt be error codes because it isnt dead yet
    Aug 2008
    Actally..Try change the filter first.. Usually when the pump dies. it is ok off the mark...most of the probs occure when starting and idling..The fuel filter being blocked or having warter in it will cause the splutter you described... When you undo the filter you will find the system is pressurized.. if this is the case then I would be looking at the filter. When you change it (Special tool required) Or try Push the fuel line hard on to the filter then pull back on the retaining locks on the collar (You will see what I mean when you look at it) Then whilst holding the retaining lugs in, twist the fuel line back and forth and pull fuel line off the filter..(Hard to do until you know how} Once you have got the filter off..Blow through it from the engine side and see what comes out..if it is clear change the pump. If shit and wter comes out..Thats the prob
    VT Acclaim V6
    May 2009
    Thanks for the great advice guys. Fuel filter was changed 100,000kms ago. The car's now at 240,000kms.
    I changed it myself, so I understand what you mean in regards to the clips. From memory I should remove the fuel relay and turn the engine over to remove pressure first?
    Anyway, I'll grab a filter and try that, and if the symptoms persist head off to Burson's for a pump and a fuel tank drop out. I assume you have to drop the tank for a wagon?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Hey malibu91, how about coming back here and letting us all know how you got on when you changed the filter. It would be a good referance to others when searching for info who have the same symptoms and are looking for answers.
    good luck!
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Before you buy a new fuel pump, I've had this happen before, but it was the immobilizer turning the car off, and the reason was the 2 metal parts in the ignition barrel had moved, and the key wasn't contacting it the whole way, it would always almost start then die, then i'd try again and it would work, I rotated the ignition barrel to line it up better and worked fine.
    Then ages later the fuel pump actually died, but the exact same situation, both completely unrelated, so before you shoot off to buy a new fuel pump, just check that first to make sure. Otherwise it really sounds like a faulty fuel pump, if it's struggling to start you can hit the tank with a hammer (not too hard otherwise you'll crack the tank) and if your car starts then its definitely the fuel pump.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Quote Originally Posted by ruggj View Post
    This. If it kicks once then stalls it is the anti-theft. Try a spare key if you have one, and make sure the silver ring on the column is clean. It is a very common issue.
    VT Acclaim V6
    May 2009
    OK Thanks for all the info. Once I get to the bottom of it I'll post back.
    1/ Check Key/barrel/Immobiliser
    2/ Filter
    3/ Pump.
    Jules
    99 vt berlina series 1 V6
    Apr 2011
    canberra
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    I had same prob, turns out it was the immobiliser not turning off, so I replaced the key & have had no trouble since
    VT Acclaim V6
    May 2009
    OK, sorry for the delay. I keep pretty busy.
    I have checked the barrel and pryed the contact lugs out a bit. This made no difference.
    I just swapped out the filter (friggin brittle clips are a real PITA).
    I blew through the old filter from outlet to inlet and heaps of black particles came out ointo my hand. Like HEAPS.
    I assume this is old stale fuel caught in the filter.
    I'll let you guys know how I go with cold starting.
    Jules
  15. #15
    VT Series 1 V6
    Jan 2008
    Hi,
    I had this problem for months and months, then I put a new battery in and it hasn't happened since. May be a coincidence, may not.
  16. #16
    VT
    Jul 2011
    I had the same issue, turn the key would start but die straight away thought it was my fuel pump but left it because it's pretty low down my list (for the time being) ended up buying a new battery as the other one died on me. Havnt had this problem happen again (yet) the car I'd always low on fuel I never put more then $20 in.
  17. #17
    VT Acclaim V6
    May 2009
    Well the replacement fuel filter has not helped. The battery is only about 3-4months old, so I would assume it is OK. I guess the fuel pump would be next, but I'm not looking forward to dropping the tank after stuffing around with brittle fuel line clips already.
    Jules
  18. #18
    VX GTS wannabe
    May 2005
    maybe your just turning the key too fast... turn to reds... you hear the fuel pump.. pump fuel to the motor, then turn further
    but if you dont let the fuel pump do its job it may have enough fuel left behind to kick over and fire for one second and dies before the pump can catch up
  19. #19
    VT Acclaim V6
    May 2009
    That's quite an interesting thought. However having owned the car for 10 years, I have never had to sit in the garage with the lights on for a bit to get it started.
    Sometimes I need to try 3 or 4 times to get it going, and it just tries to start and then coughs and dies.
    Jules
  20. #20
    vr berlina
    Aug 2008
    Quote Originally Posted by malibu91 View Post
    Jules
    To me this sounds like your traction control engaging.....try disabling it and seeing if it makes a difference.
  21. #21
    VT Acclaim V6
    May 2009
    VX Commodore 2002 Executive v6. Ex Patrol Car
    Nov 2010
    Armidale, NSW
  23. #23
    vr wagon
    Aug 2010
    vic
    Try hopping in and closing the door. Click the key so it engages unlock. Put the key in and start. Mine does the same thing. It's my effn key not turning my immobilizer off properly.
  24. #24
    VT Acclaim V6
    May 2009
    VT Acclaim V6
    May 2009
    Well bugger me! The last 6 times I have got in the car I have tried CHA53R's suggestion and the thing has fired straight up!
    I guess I may be looking at a new key when I get tired of playing games with the immobiliser (I assume the issue is with the key, not the immobiliser?)
    Jules
  1. VT V6 taking a long time to start
    By V-ahhh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2010, 06:28 AM
  2. Engine Misfires or doesn't wan't to start from time to time
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-07-2010, 01:57 PM
  3. Time To Turbo, Where Do I Start?
    By social in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2009, 02:49 PM
  4. 95 vs sedan. dies while driving. cant start
    By LethalVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-02-2006, 09:17 PM
  5. VR wont start (v-6 this time)
    By paz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2005, 06:23 PM
