Results 1 to 12 of 12
Thread: Serivce error, VT will not start after engine swap
    asdf
    Aug 2010
    asdf
    Default Serivce error, VT will not start after engine swap
    So I just finished replacing an ecotec in my vt and when I got to try it out the "SERVICE ERROR" message pops up in the dash window and the car does not crank at all. So far I have tried resetting the computer, undoing the bcm, checking the fuses. When I did the engine swap I used the wireing loom that the engine came with. I don't have ABS and the security light is flashing. I've been told that it could be a dodgy ground or a ground that isn't connected properly, if anyone can tell me where they all are that would be helpful.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Are you using the same ECU and BCM that you had before?
    MY RIDE
    asdf
    Aug 2010
    asdf
    Using the original ecu and bcm. But I swapped the ecu for the one that came with the engine and that didn't help
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    asdf
    Aug 2010
    asdf
    Checked over the engine lots of times. If there's any I'm particular I should check please say. Also can't seem to get any error codes. Not even the default 12
    Feb 2010
    Tamworth NSW
    crank angle sensor, thats one that will stop a motor from cranking ... if i think of anything else i'll get back to ya
    asdf
    Aug 2010
    asdf
    Also if I go into the menu wher it has digital speedo fuel in tank etc it said my temperature was -40c so I checked it and it was unplugged. Pluged it back in but didn't seem to affect it. Also tried starting car without ecu and nothing changes whether it's plugged in or not
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you plug in the under dash wiring plug to the ecu loom lots of people dont
    asdf
    Aug 2010
    asdf
    в∞ѕтεכ √&
    Jul 2008
    NZ
    theres 3 plugs that go into the ecu then further up from the ecu is a plug to plug the ecu loom into the dash loom .it has all the ecu ignition switched power feed for ecu and shit in it for dash and for pcm-bcm connection
    asdf
    Aug 2010
    asdf
    asdf
    Aug 2010
    asdf
    Please I need this fixed asap
  1. Vt Beebs on start up, Engine Oil Abs lights on unable to retrieve error codes
    By fr1day_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2011, 04:16 PM
  2. Engine swap and now new motor wount start
    By v6vpute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2010, 06:12 AM
  3. 97 vt engine swap now it won't start
    By revvy67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2006, 05:51 PM
  4. vr engine and box swap, car wont start
    By patl in forum Electrical Wiring / Questions
    Last Post: 18-07-2006, 10:39 PM
  5. VP will not start, engine error on dash
    By namreks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2005, 08:54 PM
