Results 1 to 10 of 10
Thread: vt engine in vs commodore almost stalling whilst switching from drive to reverse
    05 vz ss
    Oct 2010
    brisbane
    Default vt engine in vs commodore almost stalling whilst switching from drive to reverse
    my car is a vs with a vt engine and it has a rough idle but im pretty sure that is caused by my exhuast being to hard any way ever since i changed my fuel filter and pulled my spark plugs out my car has started to feel like its gonna stall when pulling into drive and reverse and also when i stop and than take off there is a slight struggle to take off . honestly the car drives beautiful untuil i get to idle when at a set off lights or putting into reverse or drive . can any one pretty please help me that would be muchly appreciated
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    What do you mean your exhaust is too hard?
    Check you haven't got a vacuum leak. You may have knocked a hose off when you did the spark plugs.
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    Is that a rubber Exhaust hose that may of been knocked off Soop, Please explain?
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    05 vz ss
    Oct 2010
    brisbane
    mechanic told me my exhaust was to hard and was making my engine move witch caused a vibration ??? apparently needs a flexi join somewhere .
    05 vz ss
    Oct 2010
    brisbane
    all hoses are in pretty sure the one in tb is in witch goes to theback of the engine then it goes to the canister also the ones in the back of the plenum chamber are all in and sorry mate i didint mention i do have extractors with high flow cat and a 2.5 inch lukey exhaust
    VT Series 1 V6
    Jan 2008
    Hi mate,
    Pretty sure it's a vacuum leak or a problem with the ignition system. I just fixed the exact same fault on a ford festiva, turned out there was a fine hairline crack in the distributor cap.
    If you just had the plugs out and replaced the fuel filter, and the problem wasn't happening before that, then that's the place to start. Check your work and make sure everything is installed correctly, all connections are secure, plugs aren't cracked and are gapped correctly, leads weren't damaged and were installed in the correct order etc.
    05 vz ss
    Oct 2010
    brisbane
    my spark plugs arent gapped but when i put them they came at a gap of 1.5 anyway does that matter there ngk irriudum
    VT Series 1 V6
    Jan 2008
    If they are new, They should have been gapped right out of the pack, 1.5mm is right. You should still check your spark leads to make sure they are good and not damaged, also recheck the plugs, it's really easy to crack them by over tightening, doesn't take much.
    Also check your fuel filter to make sure that you installed it correctly.
    Both plugs and fuel filters can cause the car to stall, so it seems no coincidence that the issue started after you changed these items.
    05 vz ss
    Oct 2010
    brisbane
    replaced leads and also replaced oxy sensor as it was a few points out but when the cars ccold it doesnt do it but once its at normal operating temp its starts to vibrate and get a rough idle and almost stall takin off at the lights and struggles to take off for a few seconds
    05 vz ss
    Oct 2010
    brisbane
    any one help with this one would muchly be appreciated . im goona try replace the coolant temp sensor today just for heck sack because that can make the car run rich
  1. VS Is stalling from reverse to drive?? Help
    By mr_kreative in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2010, 03:31 PM
  2. Vs v6 auto randomly stalling whilst driving
    By VS_WPN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2009, 01:47 PM
  3. Getting a Permit to Drive whilst Disqualified..
    By 1991_Vn2nV in forum The Pub
    Last Post: 29-03-2008, 06:10 PM
  4. Stalling (auto V6) when changing from reverse to drive. Help!
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 07:32 PM
  5. VX Commodore stalling whilst driving!!!
    By chipper_222 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2006, 12:47 PM
