Hey guys I just noticed today that my left hand side rear wheel cambers heaps but the driver side doesn't camber much at all! Anyone got the slightest clue as to why??
1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
usual suspects, springs and/or bushes. IE worn control arm bushes or partially collapsed spring on the wearing side.
worst case scenario is your cradle has cracked
revers your car a couple of meters, stop and get out,check the cambers from the rear, it should be clear if one is in more than the other.
I wouldn't be surprised if the bushes n that were ruined because it's just about to click over to 300 thousand, but it confused me cause I lowered it the same amount both sides but one cambers the other doesnt, how would I check to see if the cradle has cracked? Where would the crack be??
did u put a camber kit in at all? if so depending on which u used, 1 side could have slipped.
Na haven't done a camber kit, it was completely stock I Just changed front and rear springs
